Results 1 to 5 of 5
    firstmopar's Avatar
    firstmopar is offline 2005 chrysler 300
    Sep 2008
    Bowmanville ON
    lowering springs
    Does anyone know if lowering my 07 Magmum will affect my warranty? I'm looking at a set of Eibachs for a mild lower.
    Carbon27 AutoSports's Avatar
    Carbon27 AutoSports is offline Engineering and Design
    Dec 2008
    Orange County
    same here. i hope you get some replies
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    It will affect your other suspension components. So yes the warranty can be voided on those parts.
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    Big D's R/Ts's Avatar
    Big D's R/Ts is offline '68 R/T & '08 R/T...40 years of mopower!
    Jan 2008
    american canyon,ca.
    Talk to your dealer and see if they will install the Mopar p5153327 springs(www.moparsupercenter.com) and non load leveling rear shocks on your mag.Since they could be considered a mopar "accessory" item, they might not void the warranty if the dealer installs them,D.
    Mar 2008
    I've had warranty work done, tension strut replacements, since having sportline springs and pro-dampers. No issues, no questions. Guess it depends on the dealer.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
