Results 1 to 5 of 5
    J12_300's Avatar
    J12_300 is offline Jealous of RT/SRT8 owners...I want one!!
    Sep 2008
    Sacramento, CA
    Lowering questions for 3.5L???
    1st:
    Saw on another thread that lowering springs made for 5.7 can be used for 3.5, but wont lower as much due difference in weight...is this true?
    2nd:
    Can you throw on lowering springs without changing shocks/struts and still lower the car or is it that new shocks by Eibach or Koni come shorter that stock shocks?
    3rd:
    Are there different shocks to buy for 3.5 vs 5.7...such as the Eibach or Koni....and which would work better for the 3.5L?
    I currently run 265/35/22 with 22x10 wheels all around and was told I could only run the Mopar Springs since they only lower 1".
    Goes back to question #1
    Could I run Hotchkis Springs which are rated at 1.25" drop or Eibachs without rolling my fenders!!!
    Thanks for any input!!!
    www.CenCalLX.com
    All my photos taken with Sony DSC-R1
    *upgrading camera real soon*
    Mar 2008
    Hi Jon,
    Eibach lists different part numbers for V6 and V8
    Yes you can leave the stock shocks on if you wish.....But.....You may have bouncy issues.
    It's always best to replace the dampers when you go to lower performance springs. No necessary, but best if you can.
    Dampers (shocks) have no influence on the height of a vehicle unless they are self leveling shocks.
    But you do have to buy the set that is right for your vehicle. Again, Eibach lists different part #'s for V6 and V8
    The Eibach pro dampers and the Koni STR.T dampers are both great parts.
    You could run the Hotchkis or the Eibach pro-kit on your car without issue. You really would benefit by getting the dampers also.
    Let me know if you have any other questions.
    BTW - Eibach makes the Pro system kit for your car which includes the dampers and springs. You might be interested.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    SRT5150's Avatar
    SRT5150 is online now 500hp of Techco Screwedness
    South San Francisco Ca
    Just buy my KW's and we puts them in dis weekend.... All better....
    Mark
    2007 Magnum SRT8 aka"Beast"
    J12_300's Avatar
    Sep 2008
    Sacramento, CA
    Quote Originally Posted by SRT5150 View Post
    Yeah...I wish!!!! Dont have those kind of funds!
    www.CenCalLX.com
    rsmith63's Avatar
    rsmith63 is offline INFERNO RED RT MAG
    Nov 2008
    SARASOTA FL
    yeah different parts for 3.5 vs 5.7 ---and if you buy the springs without the shocks your stock shocks will go out eventually from over compression due to the new low ride,--- I have also heard that springs for the hemi doesn't lower the V6 car as much because of the lack of weight as well--- if you use 5.7 springs it may work may not --- stick with the right set up it will pay off in the end! you may want to roll fenders since you have 22 by 10
