Results 1 to 14 of 14
    AreTee's Avatar
    AreTee is online now BATMOBILE.
    Aug 2008
    209 [CALI]
    Lowering KW front a bit..
    So, I'm trying to lower my ride a bit. I currently have KW V2's and sit pretty low, but want to get to the max. Look at this picture...the big pin up top, I can twist it about 5-6 times, but there is no noticeable drop or raise. What am I doing wrong?
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Front end should be jacked off the ground before the adjustment is made.
    AreTee's Avatar
    Aug 2008
    209 [CALI]
    Ok, I should then be able to twist that thing on top a lot more to get the look I want. Is that what you're saying?
    Crazy R/T's Avatar
    Crazy R/T is offline previously Black R/T 06
    Feb 2006
    South shore of Montreal, Canada
    The part in your picture is for dampening adjustment. The part you need to adjust for lowering is on the shock itself behind the wheel not under the hood.
    06 Magnum R/T brillant black
    , JBA headers/mid-pipes, C&L CAI, Predator CAI 91 tune, BT pistol grip, Kicker audio upgrade, MSRT wheels
    AreTee's Avatar
    Aug 2008
    209 [CALI]
    Quote Originally Posted by Black R/T 06 View Post
    Any pictures for reference? Still gotta jack the front up right?
    Bizzle's Avatar
    Bizzle is offline Stock Sucks!
    Dec 2007
    Riverside, CA
    Yeah, the front needs to be jacked up. I can't access the kw website from work but there are instructions on there with some bland pictures
    2007 Charger R/T 6.1GONE!!!
    UNDER CONSTRUCTION
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by AreTee View Post
    Yes, still have to jack up the front. There are special wrenches that are required to change the ride height. Whoever installed the KWs for you, or sold you the car, should have given them to you along with the instructions.
    SMosher's Avatar
    SMosher is offline NorCalSRT-8
    Modesto Ca
    AreTee, Thats the dampner adjustment you are playing with.
    You need to hike the car up, pull the tire and use the adjustments there to lower the car.
    I'll miss you big brother!
    AreTee's Avatar
    Aug 2008
    209 [CALI]
    Quote Originally Posted by SMosher View Post
    I need the special tools or? Any pics of that particular part? Thanks Steveeeeeeee!
    Mymopar's Avatar
    Mymopar is offline Punishing the competition
    New England - CT
    Quote Originally Posted by richierevs View Post
    As stated that adjustment is only for dampening. To change the ride height you MUST jack up car, pull tire off. Then you will see the assembly, spring and plate. The plate shoul dhave a small set screw (meaning you need an allen wrench to loosen) so loosen the screw and then lower the plate the spring sets on by spinning it. The tools help in the adjustment but you shouldn't need them, you can spin them by hand if you have the car lower. Also be sure to clean the threads before moving the plate so it doesn't bind up on you. Lastly, depending on the drop, you may need to get another alignment. Make sure you do the same to the other side.
    Also you will need to reset the dampner to proper adjustment.
    392 Modern Muscle Stroker, 3.06 rear, 2800 stall, Fri Stage 3 heads, ported TB, SLP long tubes, SLP underdrive pulley, Silver Box, TZ Chally hood, custom BT, KW V2 Coilovers, Hotchkis sways and custom fabbed End Links
    1969 (oo===]|[===oo) 1973 (oo /=====\ oo)
    1998 (O|||||||O) 2006 (Oo.|==+==|.oO)
    SMosher's Avatar
    Modesto Ca
    See the purple ring? Thats the hieght adjustment
    SMosher's Avatar
    Modesto Ca
    See the ring at the top?
    Yeah .. Pull that put ...
    AreTee's Avatar
    Aug 2008
    209 [CALI]
    Dude you can do it by hand huh? It's as simple as screwing it?! Sweet. Thanks for everything Steve, I freaking appriciate it brotha I swear. ))
    SMosher's Avatar
    Modesto Ca
    I'm trying to get something hooked up at Kens so we can at least lift the car. Floor jacks would work and be a simple replacement but its so much easier.
    Not to mention Ken and Nan are great folks and I havent seen them for awhile.
    I will call him tonight on the way home to pull in some dates.
