I purchased the KW V2's for my Mag RT AWD and had them installed and after the the alignment and everything, the rear has a negative camber that is not within spec. So I called up Jason at HHP and put an order in for one of the Eibach Alignment kits...Here's the question...their website states that it's not for the AWD...What's different on the AWD Mag and the regular 2WD to make it not work...I'm not sure and neither does Jason and Eibach's site says nothing. Will the Eibach kit work? Has anyone else had this problem and if so what did you use to correct it... Thanks in advance.
