I'm trying to put together a spreadsheet with the NET result of lowering the LX using KW coilovers. It is my hope it will make it easier to dial in the desired amount of drop during the initial install and limit the need to readjust immediately.
I already have numbers from Meister, Hops23, and Daniel454. Thanks for your posts guys! Do any of you know the min/max for 'A'? Is 0.0" minimum, or ??
Are there any other KW owners out there that have reasonably accurate measurements? It will help a lot if you have before, after, and 'A' measurements. Also, which car did you put them on and when were the "after" measurements taken (immediately or after settling)?
So far the method of measuring has not been consistent enough to yield accurate results. Some measurements are missing the "before" numbers, some measures are to the ground, but w/o stock wheels, while other measures are to the hub center. Hub center to top of wheel well opening is preferred since this removes the wheel/tire height variable.
If/when I come up with anything useful, I'll post the results. If I ever receive my KW order, I'll at least have all the accurate measurements for a stock Mag R/T AWD using the V2s.
Thanks all...
, UltimatePedals,
