I'm trying to help out a friend here. Does anyone have any info on what needs to be done?
Ask 50 cent...he's got 26's on his LX lol other than that I think depending on your car you need rubber band tires, and you need to shave that nut down...the one just about your front two tires and I would roll the fenders
Posted via LXFMobile
My friend had to cut the spindles down and im not sure what else shave the wheel well lift it about 1 inch to get a little bit more of a "meatier" tire as he would say
There are bolt on extended spindle kits by bigboi customs for about $1000.......bolt them on, bolt the rims on, done
Just tell him he shouldn't "dork up" his car. But that probably won't work, so the above advice is about as good as it gets.
Saw this the other day on a maggie. Im by no means a fan of this, but to each his own. Hard to tell from the pics, but his fenders are ALL f'ed up from rubbing.
JNL HYDROGRAPHICS GETTIN' THEM WET, ONE AT A TIME!
Damn surprising how people act like kids just cause it's not their taste. This guy comes in here for help and gets a bunch of crap comments. Weak tits!!
Bro I'll help you out. All you need to do is lengthen your spindles, roll your fenders, get the right offset on your wheels, use the 275/25 26 size tire (less hassle) Done!!!!
2000 Jeep Wrangler
1966 Dodge Monaco 500
PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
He must like red beans and rice.
Thanks for the helpful info from those who actually helped! Moderator can close the thread.
ASK TUPOK HE'S GOT 30's
THANKS
SON
First LX Forum Member To Hit The 12 second Mark In The 1/4 Mile With A 5.7L Motor. Period.
12-16-05@L.A.C.R. Palmdale , 12.947@106.08 ET, 1.909 60ft, 10.770 1000ft and .002 RT at 50 degrees
Mods at time of run-GSM NOVI-1200 S/C SYSTEM, Dyno-Teck Long-Tube Headers, High-Flow Cats, a Borla Cat-Back System, and 18 inch BFGoodrich Drag Radials. L.A.C.R. R.I.P
SIMPLY SOUTHERN
