    rcboarder76 is offline LX Padiwan
    Sep 2008
    looking for advice and info
    hey my lil brother has a magnum r/t and when he got it, it was already lowered and he was thinking about getting a srt8 suspension. now will they work out of any lx car? and last question what about the R/T suspensions or Daytona suspension... what should he go with? any info is greatly appreciated.
    Mar 2008
    First off a couple of questions. How much is the car lowered and how is it lowered? What type/brand of springs? Were the oem shocks replaced? The reason I ask is that you may already be better off with what you already have.
    How low does he want to be? Does he want performance, looks or both? Finally, how much $$ does he want to spend?
    R/T or SRT can be installed on any Magnum. Some may need a liitle more effort. For example: The V6's don't have rear sway bars. If you want to put them in you need to buy brackets, end links and 8 bolts (4 for brackets, 4 for end links)
    Talk to your lil bro and get some of those above mentioned questions answered. You can get much better direction with that info.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    Sep 2008
    well from the looks of it hes about as low as your magnum and hes tired of scraping on everything and he is going away to college... im not sure his setup as it came with the car, my dad is looking to swap out the springs and shocks and struts from what i understand... we are looking at the daytonas. and the srt's. another thing is my brother says he also does not want to be at stock ride height but not as low as he got the car....
