Originally Posted by
moonstreaker
Just out of curiosity...did they check out your driver's side shock/spring and the mounts? You could have a sagging spring, busted shock, or even a cracked mount on that side. That could lead to uneven weight distribution, possibly causing the car pulling to the left even though it is aligned properly. Hit any major pot holes or get into any fender benders right before the problem started? Also, make sure they check the hub on that driver's side front rotor. There are so many if's that it's not even funny. I know this is driving you nuts at this point, but try to stay sane. I'm sure everyone here will do the best they can to help you figure this one out. Best of luck to you.
The mounts should be good. I should note that since they replaced the shocks/struts, I have since replaced them with SRT8 takeoffs (shocks/struts/springs). Problem did not go away although handling is significantly tighter. Could loose bolts/nuts anywhere in the front cause this?
I get road wander as well as the pull. But I'd like to fix this pull first then address the wander. Its very annoying and sometimes dangerous (when maneuvering through traffic) to drive with the wheel 20-30* to the right to keep straight while fighting a steering wheel that wants to center itself.
I will ask about the drivers side hub
sidetrack
Anyway, it looks like they need to look at the more unlikely areas.
How about the power steering gear?
Or maybe ESP is screwed up and applying the brakes on the left side. Try disabling ESP, for what it is worth.
Never thought about the power steering gear. Could that really cause a pull? I will disable ESP via diablo and try it out today. Also, does anyone know a good test for the hubs? I know about the tie-rod test (lift car and grab tire at 9 & 3oclock and shake). Is there any type of DIY hub test I can perform?
2006 Dodge Charger RT - 6.1L motor, 3.06 rear, Brembos, SRT steering & electronics * KWV2 suspension * Hotchkis sways * BWoody endlinks * SRT fascia & spoiler * Trufiber SRT hood * MSRT wheels * 6000k HID lows/fogs * Aftermarket LED headlamps * MyGIG * 1ST COMPLETE '06-'08 INTERIOR CONVERSION * AFE Stage2 CAI * catless mids * 170 tstat * Predator 93oct tune... & a bunch of other sh!t I cant remember!
