What Is The Largest Tire Size I Can Put On The Front And Rear Of My R/t With The Stock Rims?
Imports... It's what's for dinner!
255/55/18
WWW.DodgeMagnumGrille.com
What NC-SXT said
I got that size in Toyo Proxies and they are some pretty good runnin tires. I heard the KDW's weren't bad either.
Thought So.... Thanks Guys!
that depends on what you mean by large, are you talking width, overall diameter, or both. as far as width goes we have put a 275 on the front and a 315 on the rear. if you are talking about changing your overall diameter you may not want to do that. many features of your car run off your car having the correct overall tire diameter which is approx. 28.65 inches. if you change the tire diameter you can affect many things, such as your speedo, odometer, ABS, TCM, traction control, ect etc. plus many times if the dealership wants to be an a$$hole they will try to not fix things under warranty because you have the incorrect tire diameter if the issue you have is related. so you want to stick with a tire that is the correct overall diameter for your vehicle but you can wider and you can go larger with your rim size. the car will hold a 24 inch rim as long as your tire size is correct. if you want to tell me what you intentions are i can suggest the right size tires for you and tell you why. feel free to call me here at the shop. mon-fri 10am-6pm east coat time. 1-877-859-2571. if anyone else has tire size questions feel free to call as well.
I Want To Go As Wide As I Can While Staying With The Same Overall Height And The Stock Rims.
255/55/18 is it. I ran this size for several years without any issues.
My Duster is getting an Inertia Motorsports HEMI!
Didn't you make it to the Texas ALL MOPAR event benefiting the Tx School for the Blind?
