    ONE LOVE's Avatar
    ONE LOVE is offline LX Guru
    Jan 2009
    The Beach- Orange County , California
    Kwv2 settings????
    I just installed KWV2s Yesterday and need help setting em up!!! I want it stiff and to corner like a mofo!!! Also as low as i can go without pulling from the top performance!! Whatcha think???? Thx for lookin
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    Dialing them down all the way will cause the seals to blow out. I put mine 1/2 turn from all the way down and leave them there.
    Dunno what you mean by "pulling from the top performance". They have no effect on the motor output. By dialing them stiffer you reduce ride comfort. Opening them up ioncreases comfort. Only effect is a difference in rebound...
    ... which brings me to cornering. Coilovers - as far as the shock part goes - do little for cornering. They decrease body roll some and thats good. They increase control by quite a bit since they can take a lot of road imperfections and smooth them out so you aren't bouncing all over the place. But they are only part of the overall solution. If you lower the car with the V2's then you lower the car's center of gravity and *that* is where you are going to see big improvements. I'm 2" down in front and 2.5" down in the rear, but the lower-in-the-rear thing is for road racing and better control under extreme deceleration.
    If you want serious cornering improvements, do sway bars. But that is a MAJOR ride comfort change. Be sure you really want it.
    And if you really really want cornering capability add in Pedders bushings. That ain't cheap but it covers the last 10% of "do-all-you-can-do".
    ONE LOVE's Avatar
    Jan 2009
    Got it.. thanks a bunch!!
