Results 1 to 8 of 8
    CoolVanilla's Avatar
    CoolVanilla is offline The Dude Abides
    KWv2 adjustment tool: an old GM carb tool?
    Check this out. Was BSing with one of my shop guys today, and we got on the subject of my suspension. That reminded me I've yet to make a tool long enough to reach into the holes in the rear plastics of my Magnum, to adjust the KWv2s. I grab my plastic purple deal KW gives you and show it to him.
    "I know I've seen this before... Damn what is this? We should ask Bob..."
    And literally as the words come out of his mouth, around the corner comes Bob, our Snap-On guy, in his truck full of tools. We show him the tool, and he doesn't hesitate.
    "Here, see if that will work"
    And for size comparison (yes that is an official Dwight Schrute bobble head!)
    Works perfectly! What is it? Its an old GM carburetor adjustment socket!
    No doubt you can pick one up somewheres pretty easily should you need one (search on Double D Carburetor tool, 3.5mm), and if you don't want to cut your current tool in half and add a length of tubing.
    Snap-On PN of the socket: S6139
    Snap-On PN Mini 1/4 driver: TM3
    chasb's Avatar
    chasb is offline LX Guru
    Aug 2005
    In sunny Florida I'm back in NY for the summer)
    Quote Originally Posted by CoolVanilla View Post
    Have you had to re adjust the heights on your KWV2's yet. I have to since they settled way more than I thoght they would and I'm scraping front and rear on almost every driveway I hit.
    2006 Brilliant Black 300C
    Gold Award-20th Florida MOPAR Nationals 2008
    3rd Place 300C Class Carlisle 2008
    1969 Dodge Dart GTS 440 565 HP 4 spd
    Class adjusted SME Judging Score 89.5 Carlisle 2008
    BEST IN SHOW Pearl River Car show 2010
    BEST IN SHOW 2010 Pelham Car Show
    10's but I'll never race it.
    Quote Originally Posted by chasb View Post
    Have you had to re adjust the heights on your KWV2's yet. I have to since they settled way more than I though they would and I'm scraping front and rear on almost every driveway I hit.
    Not yet. I had the fortune of having mine installed well after a couple of friends had... and they both advised me to set them high; around 1/2" to account for settle. Now, 10ishk miles later, these have settled right where I wanted them.
    I hear, though, that adjusting the fronts is no trouble. The rears however... apparently you essentially need to pull them to gain access? Can someone confirm that?
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    Yup, did mine a few weeks ago. The fronts are simple. For the rears, the easiest way I found (actually help from a forum member) is to take out the inner bolt of the lower arm. The spring sits on it. With the car on stands, use the jack to slowly lower until the spring clears the collar. I lucked out with my first adjustment. Othewise you have to do it over if you need to lower/raise it again.
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    Beans to you for figuring this one out CV. Gotta have one of these. Will start searching the Web for a Snap-On dealer.
    You need to pull the lower suspension arms to pull the tension off the springs, which sit on the adjustment rings.
    EDIT: Ordered the socket from the Snap-On web site for $10.80 with tax and shipping.
    EDIT X 2: Has a handle and a flexible shaft as well as the socket. Ten bucks: http://www.sjdiscounttools.com/kdt2776.html
    hops23's Avatar
    Nov 2005
    Chicago, IL
    Here's what I made. I just dremelled the outer ring of the KW tool and inserted a small flathead sdrewdriver in the other end and walla!
    MAGNUM8R's Avatar
    MAGNUM8R is offline Yes I am a pirate, 200 years too late
    So. California
    That's a great tool, had to modify the KW plastic tool to adjust the rears on my Magnum!
    I like what I have though, easy to accuratly count the rotations out from full hard....
    Did I say full hard? Oh Man, I'm in trouble now.....
    An over 40 victim of fate.
    '8R'05 Magnum RT Midnight Blue Pearl
    KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
    Hi Flo Cats
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    cool!!!!
