Results 1 to 15 of 22
    robbyho's Avatar
    robbyho is offline the curiously strong robbyho
    Dec 2005
    Milford, CT
    KW V2's, eibach pro
    This is my first post in this section, so obviously suspension is not my thing. Your advice is appreciated. I have an eibach prokit on the way, that I had planned to install on my Mag RT, but now I got offered a KW V2 kit in a trade. The KW kit is missing the shocks, so I would have to get new ones.
    I'm mostly looking to lower my Mag while keeping the ride as smooth as possible. Improved handling is a bonus, but not my number one reason for the suspension upgrade.
    I might use the eibachs and take the V2's to sell them. What could I expect to get for these? What shocks should I get for them?
    How much improvement will the V2's give me over the eibach springs?
    Thanks guys, much appreciated.
    Rob
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Find out if you can even get the KW shocks seperate.If you can go with the V2's.
    BFNY PERFORMANCE
    RIP My Friend
    robbyho's Avatar
    Dec 2005
    Milford, CT
    I'll check. Do I have to go with the KW shocks or would another shock work/be better?
    Rob
    robbyho's Avatar
    Dec 2005
    Milford, CT
    They are definitely available, but i'm not sure of the cost yet. Thanks for your help thus far.
    Rob
    Hemi31's Avatar
    Go with the KW's.The V2's are adjustable so you'll want a matched set.The Eibach's with Eibach Dampers are very good,I had them myself.But if I could get an adjustable setup for a trade....definately V2's
    BFNY PERFORMANCE
    RIP My Friend
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    By "without the shocks" does that mean "without the two rear shocks"? as in the front coilovers and the rear springs are included? That won't be cheap.
    BUT... KW's are light years ahead of Eibachs. Especially since the Eibachs will eventually kill the stock shocks, and you'll have to go get a new set eventually; sometimes pretty soon (depends on your driving style).
    Not sure where you would only get a rear pair of any shock. Can't be cheap.
    robbyho's Avatar
    Dec 2005
    Milford, CT
    I'm pretty sure that they have everything but the actual dampener. If that makes sense at all? So all 4 suspension units, but no shocks on any of them.
    Like I said, I'm a newbie to suspension.
    Rob
    Hemi31's Avatar
    Quote Originally Posted by robbyho View Post
    Rob
    If that's the case keep the Eibachs and get a set of Eibach Dampers.You'll be very happy and it will cost you waaaay less.
    BFNY PERFORMANCE
    RIP My Friend
    Feb 2005
    At the bus stop...
    Well, the fronts are integrated coilovers. So there are no 'shocks' on the front, so to speak. A coilover is kind of a shock and a spring built into a single unit. Not something you can separate.
    So if someone told you that a set of V2's was "missing the shocks" then strictly speaking that should mean the front coilovers are intact and the rear springs are there. But the rear shocks are missing.
    A set of Eibachs plus a set of dampers is about what you'd pay for any set of coilovers you can find. KW V1's, Eibach Pro Street S and so on... although the new ST's that just came out are cheaper if you buy them on the HHP group buy. Think this one thru.
    As Hemi31 suggests, if this set is missing too much don't screw with it. Let your wallet be the decider there. Look at the cost of a set of Eibach dampers, plus the springs, and decide that way.
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    I just installed the prokit about a month ago. It is a pretty harsh ride and I am pretty sure I will need the dampers soon. Dunno if the RTs have better stock shocks than the SXT though. probably
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    robbyho's Avatar
    Dec 2005
    Milford, CT
    Good advice. If I let me wallet be my guide, what would a set of KW V2's sell for if they were slightly used? I can't seem to find any used ones for sale anywhere to get a price.
    I can sell the pro kit springs for about $150, I already have those on the way.
    If I take the Kw V2's on a trade, figure they cost me the same as the eibachs. I'll have to get new dampers for either set, so it will basically come down the resale value of each and how much the dampers cost me.
    hmmm...am I correct to assume that the KW V2's will offer better performance than the eibach pro springs with eibach shocks?
    Rob
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    I would get the guy to be REAL REAL clear as to WHAT EXACTLY you're getting..........I read it to mean you're getting 4 coil-over springs with no shocks / struts........thats worthless.The Eibach springs / struts are reportedly kick @$$.
    robbyho's Avatar
    Dec 2005
    Milford, CT
    Quote Originally Posted by MomsR/T View Post
    yup, I already sent him a pm asking just that.
    Bubba's Dragon's Avatar
    Bubba's Dragon is offline The NEW KRT
    Mar 2006
    Daegu, South Korea
    Hey ROB, the Eibachs are nice. I am selling a pair, only thing like others have said is you will need new Shocks... aka dampeners.. The ride is lower than an SRT and corners nice but man the bumps hurt with stock Shocks. U can probably do a cheaper deal with getting used Eibachs and new dampeners than getting KW stuff. I''l check on the Shocks for Eibachs and post follow up. HHP has them listed for $659.00 http://estore.websitepros.com/802805/Categories.bok?category=Dodge+MAGNUM%3ASuspension Summit has them for $699 http://store.summitracing.com/egnsearch.asp?Ntt=2873840&searchinresults=false&Nt k=KeywordSearch&DDS=1&N=700+400280+115&x=39&y=8
    You can probably get them cheaper from HHP just give Josh or Electrofied a call. Hope this helps.
    Hemi31's Avatar
    The Eibach Dampers will run about $600.A used set of KW's will run $800-$1000.If you already have the Springs I'd just order the Eibachs.
    BFNY PERFORMANCE
    RIP My Friend
