Results 1 to 4 of 4
    SilverSteelMopar is offline LX Newbie
    Jun 2008
    Austin, TX
    KW-V2 AWD part number
    Does anyone know what the KW Variant 2 part number is for an '07 AWD 5.7L V8 Charger?
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    Their website doesn't show and option for AWD. http://www.kw-suspension.com/flexshop/ Try one of the vendors here. I got mine from HHP. I had KWs for my 05 AWD Magnum RT so I imagine that there is an application for the Charger.
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    Jun 2008
    Austin, TX
    Quote Originally Posted by hops23 View Post
    I've tried 3 vendors so far, and received 3 different opinions on which is the correct set up, since KW doesn't specifically list an application for an AWD Charger none of them are positive which part number is the correct one.
    Today I gave up on vendors and was finally able to talk to a tech at KW; he said they have not done testing on an AWD Charger so they can't "officially" recommend which is the correct kit to use.
    Jun 2008
    Austin, TX
    For anyone who is interested, here is what I've learned about the KW V2's that fit the AWD Chargers:
    The part numbers for the AWD Chargers are the same as the AWD 300 C and/or AWD Magnum:
    V8 Part #: 15227017
    V6 Part #: 15227007
    Both of these kits are identical with the exception of the rear spring rates, the V6 kit has 685 lbs/inch rear springs and the V8 kit has 855 lbs/inch rear springs.
    The KW tech I talked to said they are recommending the 685 lbs/inch rear springs as opposed to the 855 lbs/inch for all Chargers and Challengers unless you want an extremely rigid rear end.
