kw v1 v8 fit on a v6?
can the kw v1 suspension thats rated for the v8 fit a v6? will i have issues?
i know the v8 has a greater spring rate than the v6. will that be a problem?
It will fit.
Spring rate will be a bit heavier but thats it.
Will the greater spring rate allow it to drop a lot more or less? What does the spring rate actually mean?
it means the lowest you're going to get the front end it approximately 1/4 inch higher than KW's specs for the V1's on an RT/SRT thats due to the weight difference of the V6 engine.
the back will work the same.
- You may not post replies
- You may not edit your posts
Forum Rules
