Results 1 to 8 of 8
    Hemissary's Avatar
    Hemissary is offline Made from solidified electricity...
    Calgary, Alberta
    KW - Installation Values
    Looking for feedback from those who have already installed their front/rear coil-overs before I start mine this coming weekend;
    Basically I after the final "A" front and rear dimensions achieved for a given drop (the actual amount of measured thread below or between the rings) . My vehicle is a Magnum R/T.
    Now the complicated part; I want to keep the vehicle level front-to-rear the idea being I am way more interested in cornering than jacked. So if you could give me your numbers and fudge for what it would take to get it near level, I would be very appreciative.
    I really want to reach the bottom limit of adjustment, in other words as low as I can without compromizing the inner/outer fenders. I would be game to curl the fender flanges, but for now would like to see where I can get without this extra step.
    Or, please point me to a shop (like a phone number) who has installed numorous sets on Maggies so I can pick their brain....
    Thanks in advance guys...
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    I had mine at 1 1/4" for the fronts and 3/4" for the rears. I had an AWD. Here's some pics.
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Go an 1" front and back, that'll drop you over all an 1" and you won't rub. If you think that's too low, bump it up 1/4. Luckly the fronts are easy to adjust, it's rear that are a PITA.
    Here is a pic of the rear set at 1", his fronts are about .8 I think. Contact Dupie24 and ask him what he set the fronts at.
    Hemissary's Avatar
    Calgary, Alberta
    Thanks hops23, your pics are not present however;
    Are you happy with the clearance, in other words do you think you could lower it more without ill-effects?
    regards
    simon in cowtown
    Hemissary's Avatar
    Calgary, Alberta
    Thanks CAM, will do...
    hops23's Avatar
    Nov 2005
    Chicago, IL
    Quote Originally Posted by Moebius View Post
    regards
    simon in cowtown
    That was low enough for me. I would bottom out the front at times if I'm not watching the road. A slight dip at moderate speed would do it sometimes.
    java's Avatar
    java is offline Nuclear User
    Feb 2006
    Baton Rouge, LA
    the search feature has a lot of information
    mine is 1-3/4 front and 3/4 rear, perfectly level
    My favorite: your facts are flawed and experience sucks.....as does your attitude.
    BrilliantBlackHemi's Avatar
    Feb 2004
    Been here 7 years!
    I did 35mm front, 25mm rear, which I think is the max recommended.
    R.I.P. Dad aka DynoBob
