So I have spent the whole afternoon compiling info from everywhere about what I should do about some wheels and tires for my Magnum and I have a couple of questions. I know the offset should be 15mm up front and 20mm in back.
1) Is it better to do a 22x8.5 or 22x10 up front while having a 22x10 in the rear?
2) If doing a 22x8.5 up front what does this leave me for options on tires...I want to put a 285/35/22 in the rear(Toyo Proxes S/T) which also makes a 265/35/22 which would only fit a 22x10 front wheel.
3) Is it better to go with 20's with a setup of 20x8.5 Ft and 20x10 Rr with 255/45 and 295/45 Toyo Proxes S/T
4) With 29.? inch diameter tires up front is the bolt in there on the A-arm going to require trimming so that it won't have the chances up rubbing?
Or any other suggestions to all the gurus
