I need an alignment
I was just wondering if anyone knows of any really good alignment shops in the NY conneticut area that has a good rep for aligning high performance cars like ours. I've been to the dealership THREE!!! times and they can't get the alignment into specs. It seems like these cars need to be right on to go straight. if anyone knows of a good shop with a good rep for high performance cars PLEASE let me know. Thanks in advance!
Steve-
Did you lower your car's suspension? If so I had the same problem until I bought a camber/caster kit. It put my alignment right in line!! Straight as a arrow now. or, maybe it's your tires?
Nah it's not lowered it just started pullin out of the blue for some reason. The tires and all those things were checked but they attempted the first alignment.
have you tried crossing rotating your two front tires?
If you move the left tire to the right, and the rigt tire to the left, and the pull changes, then the tires are the cause.
If not then i'd look in to the alignment for an issue.
Which way does it pull, and by pulling i'm going to assume that you mean if you let go of the wheel it drifts off to one side. But if you hold the wheel straight it goes straight.
Rob
If you can go to Long Island, I believe that my dad's old shop still does their alignments the old school way. He hasn't owned it for about 10 years though, but that was one of the things the shop was known for. Hit me up if you want some further info.
2007 Charger SRT8
Completed!!!
2006 Magnum R/T - RIP
- You may not post replies
- You may not edit your posts
Forum Rules
