Well that's what i feel. I bled the brakes and couldn't get the pedal as firm as it used to be. The pedal stroke is a bit more, but when they bite they bite. At first I thought i was doing something wrong with bleeding the brakes, but at least now i know. Like you said, the travel is a bit more, but not much. I don't think i need to worry about it do you? Great stuff by the way Todd and jaak.
Originally Posted by
Todd TCE
The two parts with the 25.4mm bore will have no impact from one use to the other regardless of the fittings.
The MC with the 27mm bore (1.00" vs 1.062") will have been enlarged to better accomodate the larger displacement Brembo calipers. The reduced pressure will pair better with what is likely a slightly larger piston area caliper. The smaller bore MC when paired with the Brembo parts will elevate line pressures slightly and offer a slightly longer pedal stroke.
Assuming you have fit BOTH the front and rear SRT8 parts to the car you have no bias issues. However if you've done only the fronts, your elevated pressures (retaining the stock 1") may also effect both bias (due not to the MC but the change in hard parts at each end) but dynamic bias making more rear pressure sooner than the fronts get.
1" MC at 60lbs of leg = 360psi
1.062" MC at same 60lbs of leg = 339
Going larger to the SRT8 parts will reduce pressures about 8% and firm up the pedal a bit.
Mine: 2012 Dodge White Charger SRT8 6.4
Wife: 2012 Jeep GC Overland with Hemi
Sold: Black 2012 Dodge Challenger SRT8
Sold: Silver 2008 Jeep Grand Cherokee SRT
Sold: 2006 Dodge Charger Daytona modded
