Results 1 to 15 of 21
    Dupie24's Avatar
    Dupie24 is offline Go Dupont Racing!
    Nov 2004
    SoCal
    Hotchkis sway bar grease
    Gonna do the front/rear sway and KW V2 install this weekend. The rear sway bar bushing brackets have grease fittings. Do I need to use special grease? There is special grease that came with the kit, no way to get those little tubes into the zerk fitting though! haha.
    If needed I will purchase new gun as I do not want to clean the old one, I'm sure they are cheap. My old gun has just plain ol black grease, I do not want to harm the new bushings with the wrong grease.
    2005 Inferno Red Magnum RT
    Group I and II, sunroof, tow package, nav, sirius, Uconnect, auto headlights, 20" American Racing Torq-Thrust M Wheels, 245/45/R20 Kuhmo Ecsta ASX tires, KW V2 coilover suspension, Hotchkis sway bars, Zoomers Cat Back Exhaust, Aria CAI. LED smoked tail lights. Shaved rear hatch. Pinstriping by 2-Stix. Custom painted palm tree headlights w\halos & painted fog lamps w\halos by AAC.
    Custom Billet Tech "palm tree" pieces
    And lots of little visual mods that make it ours!
    RobAGD's Avatar
    Reston, Va
    Just get something thats no harmfull to the Urethane bushings and you should be fine. Hotchkis was supost to send me out several packets of grease so I could relube my front bar, its squeaking liek crazy now when its cold.
    Enjoy the ride
    -R
    Feb 2005
    GA
    Enjoy the ride
    -R
    Glad I'm not the only one with the squeaks!! I have already relubed my fronts once and it's time to do it again.
    RadarmagneT's Avatar
    RadarmagneT is offline lurKing
    May 2005
    I seem to have squeeking too. The first time, it was the front bracket bolts where loose... BAD squeeking. Tightening them only reduced the squeek. Relubing a few months ago, helped but it is back now (I need to check the bolts again).
    BTW, anybody relubed the rears? any tricks to make it easier to get to them them?
    RadarmagneT
    2006 Red Charger R/T...
    Dynatech Header&Cats,Magnaflow, K&N, Hotchkis Sways, Diablo, NoESP.
    lmbcfls is offline LX Padiwan
    I haven't had any squeaking problems (to date), but I used LOTS of the Hotchkis provided grease and synthetic grease inside the bushings before the bars went into them. If the bars are still prone to squeaking, try wrapping the portions of the bars inside the bushings with teflon tape; grease the bushings up well before you put the bars in; and lock them down. Should eliminate the squeaking once and for all.
    Super T's Avatar
    Aurora, IL
    lube the new bushings up w/ your fingers and then install 'em. use all the grease they give you. it'll ooze out all over after you pop the bushings onto the bars, but that's better than squeaks. The zerks are there in the back because it's so hard to get to the bushings to reapply grease later... you'll eventually need the gun. The fronts are ridiculously easy to reach so they don't give you the fittings there.
    Dupie24's Avatar
    Nov 2004
    SoCal
    Sounds like squeeking is a problem, I will do as told, use all the lube provided. I am gonna get a grease gun and grease for poly bushings for the rears. Is access a problem even with the rear zerks? Thanks for the replies, beans to ya all!!!
    Super T's Avatar
    Aurora, IL
    i didn't have the other car long enough to have to regrease them... but make sure you install the rears so the fittings face out, and you should only have to remove the wheel to get to them...
    RobAGD's Avatar
    Reston, Va
    Dupie - I put a 90* zerks on mine before installing so they would be a little easier to get at with a grease gun. If you havent installed yet look into that option.
    -R
    Dupie24's Avatar
    Nov 2004
    SoCal
    -R
    The brackets came with 90 deg zerks, just gotta make sure they face out like SuperT suggested. Thanks again, the install happens in a few hours, gotta get to bed so I can make it to the shop by 7:00. I'll post the results. Thanks again to all.
    Dupie24's Avatar
    Nov 2004
    SoCal
    Many thanks to all who replied here, it made the install successful! Here's a link to a thread about the install, again, thanks to all!!!
    http://www.lxforums.com/board/showth...573#post826573
    May 2005
    FYI,
    I contacted Hotchkis and they are sending me a "fix"... Hopefully they will send new bushings for the front and... drum roll please... washers!
    They sent along revised install instructions that have you putting TWO washers on each bolt between the brackets. Although it seemed to fit nicely when I put my front sways on, the brackets could be too tight and cause damage to the bushing?!?
    Instead of washers.. couldn't they have made the bushing smaller?
    I'm not sure, but after about 15000 miles on mine, they are BOTH groaning...
    Hopefully, with new bushings and the washers/spacers, I wont be embarrassed to go over speed bumps any more ;-)
    RadarmagneT
    Dupie24's Avatar
    Nov 2004
    SoCal
    Quote Originally Posted by RadarmagneT View Post
    FYI,
    Very intresting. When I installed the sway bar all went fine, lots of grease and teflon tape on the bar. Washers make sense if bushing too tight, cheaper to make washers than to make new small bushings? Will keep this in mind if squeeks start up, so far no squeeks. Thanks for the heads up here, I'll bet there are quite a few people intrested in this, thanks again.
    viper's Avatar
    viper is offline LX Padiwan
    Whiteman AFB, MO
    I had my Hotchkis sway bars and tires installed 2 weeks ago. The front of my car makes some kind of noise; I guess it sounds like a squeak. I can only here it going over bumps, never in a corner. Is this what you guys are talking about?
    2011 Challenger SRT-8
    2009 Charger SRT8 Super Bee #409
    Dupie24's Avatar
    Nov 2004
    SoCal
    Quote Originally Posted by viper View Post
    Very possible this your squeek, lube the bushing real good, have to remove the bushings to grease them, when they are out put teflon tape around the bar where the bushing ride.
    Washers on the brackets may help also, the washer would go between the bracket and the frame to bring the bracket out a little and not so tight on the bar.
