Results 1 to 11 of 11
    Husker's Avatar
    Husker is offline AG Strek
    Nebraska
    Hotchkis front sway issue
    Anyone else having issues keeping the Hotchkis front sway bar connections tight? I have had to re-torque the lower sway link to the upper A-frame on the pass side twice now. I can tell when it's loose as it rattles like a bad dog...
    Any ideas?? Maybe thread loc?
    05 Red Inferno Magnum SXT-Traded
    05 Red Inferno Magnum R/T- Traded
    06 Silver 300C SRT8 RWHP 371 RWTQ 374
    Options I,II Sunroof,Side Curtain AirBags BIG HEMI
    dodgeboy's Avatar
    dodgeboy is offline LX Padiwan
    May 2004
    Berkley, MI
    I torqued mine about 15-20lbs beyond the spec. (shh!) I had that issue with the hotchkis sways on my Durango, and that was the only solution. I didn't even bother trying the stock torque on the 300C, because I figured the similar design would have similar results.
    Dave
    2006 300C SRT8 - Inertia Custom Diablo Tune, Inertia Spartan Cam, Edge 2800 TC, Mopar TCM, Magnaflow Cats, Mopar CAI, 180 Stat
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    You mean the end links?I tightened mine gorilla tight and left them like that.Did it the same way when I did my springs last winter and never had a problem.
    BFNY PERFORMANCE
    RIP My Friend
    Husker's Avatar
    Nebraska
    Yea the end links that attach via the spacer bar..I used a rathe large pry bar to torque the piss out of it today...well shall see this time
    NC-SXT's Avatar
    NC Coast
    Try a bit of loctite on the threads next time. That will do it.
    WWW.DodgeMagnumGrille.com
    Super T's Avatar
    Aurora, IL
    Be careful overtorquing... i watched somebody snap grade 10 bolts for half an hour because they went to torque spec and then 'an extra quarter turn, just to be safe'. This guy ain't too bright, and I had to find the torque specs for him, and he still decided he knew better, so it was more fun to just watch him til he gave up. But anyway, my point is it can get dangerous. I'd advise loctite.
    dodgeboy's Avatar
    May 2004
    Berkley, MI
    Quote Originally Posted by Super T
    I agree that over-torquing is a bad idea... But just to be clear, in this situation an extra 15-20lbs was about another 1/20th of a turn (maybe 2" at the end of the 1/2" drive torque wrench). I'd imagine an extra 1/4 turn would be at least another 80-100lbs in this situation.
    And I'd never consider over torquing a crucial suspension/steering fastener, or anything where I didn't have easy access to both ends of the bolt...
    Dave
    Dupie24's Avatar
    Dupie24 is offline Go Dupont Racing!
    Nov 2004
    SoCal
    Quote Originally Posted by dodgeboy
    And I'd never consider over torquing a crucial suspention/steering fastener, or anything where I didn't have easy access to both ends of the bolt...
    Dave
    Been there done that? Sounds like you speak from experience. Very good advice, everyone listen to this, it will save you many a headache. Thanks dodgeboy, you may have just saved someone a broken bolt headache!
    2005 Inferno Red Magnum RT
    Group I and II, sunroof, tow package, nav, sirius, Uconnect, auto headlights, 20" American Racing Torq-Thrust M Wheels, 245/45/R20 Kuhmo Ecsta ASX tires, KW V2 coilover suspension, Hotchkis sway bars, Zoomers Cat Back Exhaust, Aria CAI. LED smoked tail lights. Shaved rear hatch. Pinstriping by 2-Stix. Custom painted palm tree headlights w\halos & painted fog lamps w\halos by AAC.
    Custom Billet Tech "palm tree" pieces
    And lots of little visual mods that make it ours!
    Husker's Avatar
    Nebraska
    Ok, I am thinking the loctite might be the better idea here.. But it is just the one side....I wonder if the pass side does something more then the drivers side??!
    Super T's Avatar
    Aurora, IL
    You mean in terms of ?? The force on the links will be the same on either side at any given time, just acting in opposite directions (one wheel is trying to push up, the other wheel is pushing back down, etc.). Unless everything I've learned is wrong, there's no other way for them to work. If the bushings aren't located the same place on either side, as in if they're not mirrored around the car's centerline, then one side of the bar might get a little more 'wiggle' in it than the other, that could help loosen a bolt up over a few hundred cycles.
    RobAGD's Avatar
    Reston, Va
    Put mine on and torqued as close to spec as I could ( there was one bolt that was just a right bastard to torque down on )
    No issues to date and I drive the piss out of it.
    -R
