Results 1 to 15 of 15
Thread: Hmm DR help
    tank8289 is offline Supporting Vendor
    Jun 2007
    West Milford, NJ
    Hmm DR help
    Ok i'm gonna be getting Dr's for all 4 corners. I'm thinking a 17 inch wheel. Does a 16 inch clear the R/t brakes? Anyway what size tire should i be looking at since i'm at a 3.07 gear ratio. I have been thinking 255/40/17 which puts me at a 25" tire. Or a 255/55/17 which puts me at a 28" tire. What is the best size? Also what has been the best DR to go with? First time buying DR's so who has had experience with which and which ones do you like?
    392 Stroker, Builder Bill TC, Builder Bill tranny, LXAS LVLI Tcase, Novi 1500 10.5psi, 150 shot of nitrous, tuned by Josh @ HHP
    Jun 2007
    West Milford, NJ
    Ok i found a calculator online, a 25 inch tire will put me at redline in 3rd at about 105mph which is no good. A 28 inch tire will put me at the redline in 3rd at roughly 115mph, which is much better.
    ko4000's Avatar
    ko4000 is offline Blame it on the Alcohol
    Jan 2007
    Fort Lauderdale, FL
    I would go with Hoosiers or M/T in 17 inch. Also, I dont think you need ALL four..
    AFE CAI, SLP LM II, ZEX 100Shot, Nitrous Oulet Plate , Mopar LT's/cats,
    Inertia Motorsports Perf. Heads & Spartan Cam -Ported 6.1L Oil Pump (Installed by Matt @ Michigan Hemi Performance)
    No-ESP mod, Predator Tuned, TEIN SS Coilovers, 20" Viper Replicas (custom powder coated)
    CMR Tune by Johan @ Diablo Sport
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by ko4000 View Post
    He has a stroked AWD
    RT NOMAD's Avatar
    RT NOMAD is offline Mopar Rules
    Jacksonville, FL
    I may be way off base here, but I'm thinking with such little tire slip as you should have, I'd go with the shorter tire for a quicker launch.
    That benefit should outweigh the negative 3rd gear shift point.
    (I'm trying to prepare myself to the blasted for my ignorance now)
    Terry
    2011 Charger SE (blackberry)
    2011 Ford Raptor
    Jun 2007
    West Milford, NJ
    you may be right because i have seen evos trap at like 108 with a 10-11 second run.
    Jun 2007
    West Milford, NJ
    Wow i started looking at DR's and i got completely confused. Can someone help me out with a 25-28" tall DR that will fit on a 7 inch rim (probably a 255 series).
    Trojan's Avatar
    Mar 2006
    So Cal
    You guys, alot of us have been running the shorty's! 25.5 or so, 17's will work, Tirerack has a Borbett for like 125.00, if its on a budget. Most of the record runs have been on shorty's.
    Jim "Meister" Edwards
    RIP "SLICK"
    Jun 2007
    West Milford, NJ
    Anyone heard of these DR's? Pirelli PZero Corsa
    $75 a piece!?
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    Well, here's a thought, if you have your stock 18" wheels, instead of drag radials just go with a fatter lower profile street tire, 255/45/18 or perhaps for the rear a 275/45/18.BTW what's your trap speed now?
    ko4000's Avatar
    Jan 2007
    Fort Lauderdale, FL
    Yea I understand that... Are the higgly modded Jeep guys running DR's all around?
    Jun 2007
    West Milford, NJ
    Their awd system is quite different so i doubt they have the traction issues we have.
    Jun 2007
    West Milford, NJ
    Ok here is the setup i think i'm gonna go with. I got the borbet wheels for $129 a piece at 18x7.5 (damn tire rack wont let me go to 17 inch for some reason) and then 265/35/18 BF goodrich g-force r1 (will that tire fit on that rim?). All mounted for about 1500. I'm gonna see if i can find something in 17 inch.
    Hal'sMag is offline Wax On - Wax Off
    Feb 2007
    L.A., Ca.
    Road tires and track tires should be two different concepts for your car.
    A 220 tread wear will provide pretty good traction, but low tread life on a AWD.
    Race tires are probably down in the 50-80 road wear area, and wear really quick but provide tons more traction. For a AWD (wish I had one) I'd think that the F1 supercars with a 220 rating would give best of both worlds.
    I'm going through the same thought process with my RWD, and figure I need a set of 4 wheels and tires for auto cross, and a set of DR and wheels for the 1/4, and a set of daily drivers.
    With your AWD. I think you can find a tire that meets your needs for all uses. Probably between a 180 and 300 tread wear
    Just a grocery getter!
    Jun 2007
    West Milford, NJ
    well i'm gonna be getting new everyday tires, which are also my drag tires for now, i'll see how my traction issues are then and then if i need DR's still then we'll see.
