Results 1 to 13 of 13
    zonian's Avatar
    zonian is offline LX Padiwan
    Jun 2004
    Bloomingdale, IL
    Help Removing Tension Struts
    OK, so what's the secret to loosening the tension strut ball joint without using the special DCX tool? I've been pounding on the damn thing for 30 minutes...no budge. I even put the jack under it to try to leverage the vehicle weight...no budge.
    I'm not worried about ruining the threads because I'm replacing the whole thing anyway...
    Any ideas?
    Paul
    My wife says I never listen to her...or something like that.
    klarmie's Avatar
    klarmie is offline Like Freedom? Thank a Veteran.
    Sep 2007
    New Hampshire
    Quote Originally Posted by zonian View Post
    Any ideas?
    Paul
    bigger hammer? Just kidding, do you have a "pickle fork" ? You will have to look out for the disc brake shield if you use the pickle fork.
    5.7L Hemi Registry # 00814
    zonian's Avatar
    Jun 2004
    Bloomingdale, IL
    B. F. H. woreked. One side done....on to the other.
    Paul
    progolfer82 is offline LX Padiwan
    Oct 2009
    SoCal Ride: SRT8 Mag
    I replaced mine today. I had a hard time getting the bolt out and I used a BIG flat head screw driver and hammered the bolt on the nut end and it came out like butter. Hour for both sides.
    bklynmag is offline Maggie under construction
    Brooklyn, N.Y.
    Few shots with a heavy hammer and they drop right out.
    5.7 Personal Best: 11.46 w 1.59 60'
    6.1 Personal Best: 10.405 1.566 60' @ 129.69
    7.4 Personal Best: Coming Soon
    Mods: Busted 6.1
    Rob@WretchedMS's Avatar
    Rob@WretchedMS is offline Evil Pedders Guy Since 06
    Jan 2007
    CT/MA
    do not use a pickle fork, if you have a pickle fork dispose of it as fast as possible.
    it will do nothing other than damage your ball joints.
    The best way to get the ball joint loose from the knuckle is by using a big hammer and hitting the side of the knuckle where the stud goes through. give it a couple good wacks, and don't be shy, just don't miss.
    this is how we do it, this is how the dealers do it, and this is how you should do it.
    NC-SXT's Avatar
    NC Coast
    Quote Originally Posted by klarmie View Post
    Oh ya because you can punch a hole in it. Dont ask how I know.
    WWW.DodgeMagnumGrille.com
    Oct 2009
    I took pictures of the process yesterday and will post tonight.
    gameover's Avatar
    gameover is offline voiding warranties
    May 2006
    New Orleans
    I use this and it makes the job much easier. it can be found at autozone for around $10 bucks. Loosen the nut but dont remove it and put the tool on. Be cafeful a pop will sound when you get it loose.
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    bigjim's Avatar
    bigjim is offline Damn Fast Grandpa!!
    Oct 2004
    LaFargeville, NY / Bolton, ON
    BFH and use your balls, the only way... JUst did a set for another member yesterday, 1 hour for sway links and tension struts.
    05 Magnum RT 5.7 (Member ALLPAR.com 200,000 mile club) Rockinsrt8 shifter, Hemi reg #164 266,666 miles (c'mon John, I slowed down! NOT)
    Sidewinder, 6.1 pushrods, springs, underdrive pulley, SRT exhaust (donated by NHDave) headers to tips, all installed by Hemi31! Quaife, certain Pedders bushes installed, SRT Nivomats and Bilsteins. Police rotors and pads. HIR. Predator. LMI.
    1:19 NJMP Lightning
    1:45 Mosport
    karfreek's Avatar
    karfreek is offline LX Guru
    May 2006
    Fultonville NY (Upstate)
    Well, I tried today and lost. I had a 5lb hammer and everything that I could put into it and nothing. I was hitting the knuckle so hard that it was leaving marks.
    Jay
    2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed
    2005 Dodge Magnum RT-Can you say...HEMI?
    2004 Chrysler Pacifica AWD-Everything but the kitchen sink.
    BuckeyeRT's Avatar
    BuckeyeRT is offline Life is fragile, handle with prayer.
    Jan 2006
    Home of The Buckeyes
    Quote Originally Posted by gameover View Post
    This is what I had to use. I got it from Advanced Auto part tool rental (free).
    I hit with a hammer like you would not believe. I lifted the car with a jack on the nut then hit...nothing. Puller worked like a charm.
    Got Faith? Philippians 4: 6&7
    Yup, Haz did my sig too.
    Ask me about my first kill, I bet it was better than yours!
    bigjim's Avatar
    Oct 2004
    Quote Originally Posted by karfreek View Post
    Jay
    If you have a nasty one, wind up some tension with a puller like above, THEN hit the side of the knuckle. Otherwise hit the tension strut stud up (carefully but HARD), not the knuckle.
    1:19 NJMP Lightning
    1:45 Mosport
