Results 1 to 15 of 19
    injunwiz's Avatar
    injunwiz is online now Haulin' Donkeys!
    Oct 2008
    L.A. (Lower Alabama)
    Help needed, drop SRT front only
    Hey There,
    I finished installing a 300 SRT suspension on my 05 Magnum RT. The rear sits PERFECT but the front is too high and I want a slight rake. Suggestions? Cut springs, remove an isolator? Buy replacement front springs only? I only see sets of springs and no front only for sale.... Need some advise...
    2005 Magnum RT ALL options! Shaken, STU'd, Paddled, and Dropped! See my HEMI Registry for other mods list: http://www.lxforums.com/board/f76/5-7l-hemi-registry-1090-injunwiz-154589/
    2fast mag's Avatar
    2fast mag is offline 2005 Magnum R/T
    Dec 2007
    Toronto, ON
    Some have taken off 1/2 coil on the fronts to compensate for the different knuckle from the SRT front spindle. But, they also say do not take more than 1/2 coil off as you will make the spring unusable. I have not done it myself, and have the same issue, but it is only 1/4 or 1/2" off.
    SRT8 Suspension & drivers seat, BT catch can, R & T intake and exhaust, and a sleeping Predator.
    injunwiz's Avatar
    Oct 2008
    Cutting 1/2 a coil was the idea, I got talked into trying it the way it is... Has anyone ran the front with 1/2 coil cut AND no bottom isolator? I want the nose down a little, not a level ride. With the finger measurement I can put one finger between the rear tire and fender at the top and 3 fingers on the front between tire and fender. Yes, I did run the car over speed bumps, etc to allow it to settle.
    2005 Magnum RT ALL options! Shaken, STU'd, Paddled, and Dropped! See my HEMI Registry for other mods list: http://www.lxforums.com/board/showthread.php?t=154589
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    I've ran with the 1/2 cut coil for many, many miles. No issues. Do not run without the isolator. But what you can do is remove the fingers (whatever they're called) on the isolator, smooth it out, that's good for another 1/4".
    injunwiz's Avatar
    Oct 2008
    Cam, Sounds like what I'll be doing, thanks for the tips! My rear springs are 300 SRT and I think they sit the car even lower than Maggie SRT springs. If this doesn't do it, any other suggestions? I do want to keep the front Bilstiens if there is a different front spring that will work with it.
    Boggus's Avatar
    Boggus is offline The HEMI pit
    Big Ole TEXAS
    Pedders sells springs each .....
    lowryder99 is offline LX Padiwan
    Apr 2009
    Edmonton, AB
    Quote Originally Posted by Cam View Post
    Why do you say do not remove the isolator? I am running without it and it's fine, no weird sounds or harshness.
    I would rather pull the isolator to get the mild drop needed before I cut a coil. Just my .02
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by injunwiz View Post
    The problem with the front spring is the shock can only handle so much drop before it's bottoming out. I got greedy with my front spring one time and dropped it another 3/4". That lead to several problems including blowing out the shock. But other guys have ran these shocks with lowering springs and done fine or at least I never heard different.
    Quote Originally Posted by lowryder99 View Post
    Steel on steel is not good bud. It'll eat it's self up and I'm very suprised to hear it's not noisy. I'd suggest you might wanna keep an eye on it.
    injunwiz's Avatar
    Oct 2008
    Any Pedders drop spring users input? Perhaps I need to contact Pedders and see what they offer...
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Also will drop the car too low....could blow the shocks out.
    BFNY PERFORMANCE
    RIP My Friend
    2fast mag's Avatar
    Dec 2007
    Toronto, ON
    The front SRT springs are the same, the struts are different part numbers for Mag or 300 and Left/Right
    Apr 2009
    Edmonton, AB
    But the steel on steel doesn't actually move, I could see if the spring shifted constantly on the steel but it's stationary.
    I know on any of the trucks I have worked on or lowered (gm's mainly) the coil sits directly in the coil pocket with no rubber isolators. I am picky as hell and if I heard ANY noise the isolators would go back in but I don't even hear a peep. Other guys who suggested that I run no isolators have mentioned that they also have not heard any noises.
    jg's Avatar
    jg
    jg is offline LX Padiwan
    Jan 2005
    Not true. The 300 SRT is softer. The Charger/Magnum SRTs share spring rates and shocks, with the rear springs on the Mag. about 1/2" taller. This is why many are looking to cut the front springs after installing 300/Charger SRT susp. on a Magnum.
    Quote Originally Posted by smurray View Post
    The front SRT springs are the same...
    injunwiz's Avatar
    Oct 2008
    So, Is that meaning it would be lower in the front with Charger/Magnum SRT springs instead of 300 SRT springs?
    jg's Avatar
    jg
    Jan 2005
    Not necessarily. The height of the springs is the same in front between the 3 SRT models, just the rate on the 300 is softer. The rear is where the difference is. If you install Charger/300 SRT springs on a Magnum, the rear height would be ~.5" lower than where the Magnum SRT rear springs would put the car (because of the taller Mag. SRT rear springs).
