Results 1 to 13 of 13
    sdcarguy's Avatar
    sdcarguy is offline LX Padiwan
    San Diego
    help...any thoughts...
    Just had the kw v2s installed on my car with the hotchkis sways. The front is perfectly lowered 3/4 of an inch. The back however is about midway down in the adjustment and is sitting an inch higher then stock...did we miss something? anyone else had this issue?
    2006 Silver Srt-8 Option groups 1,2,3, air bags and sunroof, KWv2s, Hotchkis Sways, Bwoody end links, tinted tails,phenolic intake spacers,Magnflow High Flow Cats and Exhaust,170 T-stat HIDs low and fogs 5000k, USW Forged DLux 22x9.5 and 22x10.5 with Vredestein 265/35 295/30, Demon Eyes, Diablo Predator, Screwed by Techco.
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    Sounds to me like they didn't set it up right, and got lazy... All you (they) should have to do is jack up the rear, remove the wheels, and loosen the set screw (2.5mm) and then use the provided tool to adjust the spring rest (or whatever it's called - the purple threaded ring that is on the strut, and the coil rests on it. I would take it back to the install shop and convince them that the job is not complete until the ride height is correct.
    If they won't play, find a new shop, but you can do it yourself if you have a jack and jackstands, etc.
    sdcarguy's Avatar
    San Diego
    its a friend at the dealership doing it for me so its not an issue of getting lazy we just ran out of ideas. the set screws are only on the fronts. The rears are just held in place by the load. The spanner nut which is the purple adjuster you are referring to can be adjusted. But the problem is its half way down now and still sitting an inch higher then stock. So we took it all down and made sure everything was in the right place. I was under the assumption that even at its highest setting it would be lower then stock. So I have to be missing something...
    Junior's Avatar
    Phoenix
    Quote Originally Posted by sdcarguy View Post
    Yeah, you're right about the set screw on the rears... and sorry if I came off wrong - had a good experience with the shop that did mine, read about others who didn't, and laziness was an assumption...
    hmm... afraid I can't help here, unless it would help to know where mine are in reference. I can go check...
    sdcarguy's Avatar
    San Diego
    http://s87.photobucket.com/albums/k1...guy/coilovers/
    here is a link to the pics...i was told to try adjusting it up another 1/2 inch but this would bottom the adjustment out...these are supposed to have almost 2 inches of adjustment...anyone anyone?
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    looks like you have to go all the way to the top with the purple colar mines almost there to the top and it has about an inch wheel gap!!
    Dupie24's Avatar
    Dupie24 is offline Go Dupont Racing!
    Nov 2004
    SoCal
    Ok, I was looking at the pics, seemed that the part # is upside down. So I had to go look at mine, sure enough, upside down. That kills the spring in upside down theory, and heck that would be hard to do. I noticed the part# on yours is 2730 ----. Cant read the rest of it. The part number on mine is 2703 GBKA. Maybe you got the wrong springs? I have a Magnum and I don't know if the Charger springs are different. But seems to me you've covered all your bases, gotta be wrong parts. If I think of anything else, I'll let ya know. This has got my curiosity up, please keep us informed.
    2005 Inferno Red Magnum RT
    Group I and II, sunroof, tow package, nav, sirius, Uconnect, auto headlights, 20" American Racing Torq-Thrust M Wheels, 245/45/R20 Kuhmo Ecsta ASX tires, KW V2 coilover suspension, Hotchkis sway bars, Zoomers Cat Back Exhaust, Aria CAI. LED smoked tail lights. Shaved rear hatch. Pinstriping by 2-Stix. Custom painted palm tree headlights w\halos & painted fog lamps w\halos by AAC.
    Custom Billet Tech "palm tree" pieces
    And lots of little visual mods that make it ours!
    sdcarguy's Avatar
    San Diego
    I thought that too but I got these from Randino69 who had them on his srt8 charger just like mine. And his complaint was he was to low...Im baffled...
    Dupie24's Avatar
    Nov 2004
    SoCal
    You just keep making this more and more complicated don't you! LOL WTF is going on? There must be something, I feel for ya. I have'nt a clue, but I will keep thinking, if anything comes up you'll hear from me. I wish I new WTF is happening here.
    sdcarguy's Avatar
    San Diego
    Ok so I have spoken with a ton of people on this topic and even KW themselves...everyone that has looked over the pics says the same thing. They are in correctly. So KW is having me put her back on the rack and bottom out the adjustment and then give them a ton of measurements along with every part number from the kit. Not sure what this will do for them other then tell them its 2 inches to high...but I am at a loss. The fact that this same kit(and I mean literally) was on a srt8 charger with the same sways and it was lowered means to me either I missed something during the install or they have a lot of settling to do...oh yeah as for settling so far the front is stable at 29 and 1/4 from ground to fenderwell and the rears are still 30 and 1/4. Stock was 30 all the way around. I think the strangest thing for me is that it handles so much better then stock. I know you are all thinking why is this strange...well the fact that they are almost bottomed out in the rear and still higher then stock to me means I should be riding around like the rear was on a pogo stick and swaying in the breeze. But its the opposite. It feels tight and really solid in the corners and rides soft down the freeway...oh well 3 more days and back on the rack she goes...
    The Ones Im Running Are From A Magnum Rt And I Have Charger Se???
    Dupie24's Avatar
    Nov 2004
    SoCal
    sdcarguy - Did you also put sways in? I drove a charger with the Tein system with stock sways and it felt pretty good, not as good as ours with the sways. Just wondering. I now know the sway bars do make a difference.
    Good luck with the resetting, at least it will be another thorough check through of everything related. Keep us posted on the results. Any pics?
