Just put 22 foose nitrous on MAG RT 05--what is the nut that sits 1/8 inch over tire? Will this hit? it seems to be rigid and fixed, is there any worry, these 22's are made for the car. thanks vic
WWW.DodgeMagnumGrille.com
They won't hit. Those nuts are in a fixed position regarding the wheel; they're part of the knuckle assembly.
1/8" is damn close. I'd suggest taking a little off. Yes, it's a fixed distance from the tire. But what if at high speed, the tire grows some. Just a thought.
I have 22''s on mine and I also clear only by about 1/8" to 1/4" and have no problems. It is fixed so it should be okay. It just looks a little scary being that close.
06 Silver Magnum R/T
Devino 430 Adana 22" Rims/Hankook 265 35 22
K&N Typhoon CAI
Billet door lock pins, Billet headrest spacers
Ultimate pedals, Billet Technologies under hood goodies
http://s119.photobucket.com/albums/o135/OregonRT/
Looks very scary but previous owner and alot of people on the forum run the same w/o problems. Should of had a shop install and never looked--even if they rubbed I would keep looks way to good!
