Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Grey Ghost's Avatar
    Grey Ghost is offline LX Padiwan
    May 2009
    Oregon
    Hawk Ceramic sqeeeeeeek
    My Hawk Ceramic brake pads are starting to squeak really bad. It is becoming very annoying. Is there anything that can be done to stop this problem? They were quiet at first, and the more miles they get on them the worse the noise gets.
    Daytona 226's Avatar
    Daytona 226 is offline My Other Boat is a Sea Ray!
    NJ
    It's a very well known issue with them. I changed mine out after 1500 miles. Just couldn't stand it anymore. Tossed in the garbage. Mine were so loud, it was actually embarrassing!
    Mods: FRI Street Heads, Sidewinder, Zoomers, Mopar LT's & Hi Flow Cats, DS Predator, DSS Axles, Ram Air Hood, Hotchkis Sways, noESP, Coolit, TranZformer, Dynamic Grounding System, Autometer C-2's, Rocker Panel and Rear Fascia Decals, Tinted Tails, Zinik S-21 Chrm. & Blk. Staggered 20's, Grip Rockers, Power Slots, Centric Posi-Quiets, AAC Halos, Billet Tech., BFNY'ed, RDP Racing Tuned, Ridergraphix, Electronics by Joe@402Motoring
    Grey Ghost's Avatar
    May 2009
    Oregon
    Quote Originally Posted by Daytona 226 View Post
    Thanks man. What did you replace them with?
    richierevs's Avatar
    richierevs is online now I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Quote Originally Posted by Grey Ghost View Post
    Is the squeek coming from the front or the rear? If you want to keep the Hawk pads you'll have to frequently "bed" the brakes to keep the pads and rotors clean so they won't squeak. Do a search on "bedding brakes" to get more info.
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    I wonder if the slotted SRT rotors (or slotted aftermarket RT rotors) would cheese-grate on the pads enough to keep them scuffed so they don't squeak. My slotted fronts never squeak. My rears are plain and they do get noisy in between track days.
    Rob@WretchedMS's Avatar
    Rob@WretchedMS is offline Evil Pedders Guy Since 06
    Jan 2007
    CT/MA
    I have the DBA Slotted rotors on the GTO and the SRT8, both using the Hawk Ceramic pads for the street.
    I have zero noises from either car.
    I would have to say that if you have noise from this combo, they were likely not bedded properly.
    With the HP+ pads i did get noise, but they are much more aggressive.
    Grey Ghost's Avatar
    May 2009
    Oregon
    I have drilled and slotted rotors; both front and rear. The fronts seem to be the ones doing most the squeaking. If they continue to get worse, and I am sure they will no doubt, I'll replace them and try something new.
    When new, I followed the recommended bedding procedure. I even had the instructions printed out along with me in the car. I have had them smoking a time or two since then during some pretty spirited driving. The have approximately 5-6000 miles on them.
    israel's Avatar
    israel is offline Now That's Woo Ha!
    Seal Beach,CA
    After installing you should bed them in and depending on the level of brake pads you got, warming them up usually stops the sqeaking.
    Jan 2007
    CT/MA
    then it sounds like you have glazed the pads, (and possibly overheated the rotors, as drilled rotors are not that durable)
    You should check the rotors for heat spots, and cracks.
    The best course of action on the pads would be to replace them.
    I'm going to assume that they didn't make noise until you overheated them.
    Feb 2005
    At the bus stop...
    That may be your problem. You may have glazed the pads? Bed those suckers again.
    Grey Ghost's Avatar
    May 2009
    Oregon
    Quote Originally Posted by Rob@WretchedMS View Post
    You're right!! No noise till I overheated them. I will be replacing them soon then. It sure didn’t take much to overdue it with these things. I’ll try the rebedding, got nothing to loose, and then go from there.
    Jan 2007
    CT/MA
    The rotors are what will dissipate the heat, not so much the pads, so upgrading the rotors would be a good idea if your overheating your current setup.
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    FWIW, drilled rotors don't do well on LXs. Do a forum search on rotors to get more info.
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    ill post pictures of my cracked slotted/drilled rotors if oyu want
    i now have slotted only front rotors with HP ceramic pads.
    i have to bed them often just to stop the squeeling.
    i hate them.
    they do bite a bit better than the posiquiets i had before tho
    NYC
    Idk why you guys all put up with ceramic pads. Just to get rid of a bit of dust? At what expense?? noise and stopping power?
    Give me gold ol' reliable semi-metallics any day.
    2006 Dodge Charger RT - 6.1L motor, 3.06 rear, Brembos, SRT steering & electronics * KWV2 suspension * Hotchkis sways * BWoody endlinks * SRT fascia & spoiler * Trufiber SRT hood * MSRT wheels * 6000k HID lows/fogs * Aftermarket LED headlamps * MyGIG * 1ST COMPLETE '06-'08 INTERIOR CONVERSION * AFE Stage2 CAI * catless mids * 170 tstat * Predator 93oct tune... & a bunch of other sh!t I cant remember!
