Results 1 to 15 of 22
    Nuclearjack's Avatar
    Nuclearjack is offline I drive!
    Halifax Nova Scotia
    God awful squeak/creak coming from the suspension.
    It used to happen only when I had a passenger in the car and now it happens all the time.
    It is coming from the front drivers side wheelwell.
    I have this incredibly loud squeak/creak coming from the drivers side suspension. It happens on the slightest bump on the road.
    I can replicate the sound by turning the wheel while in park or by pushing the fender down with my hand.
    Im guessing one of the bushings needs to be replaced or at least greased but Im wondering which one. The car is going to the body shop on Monday but I was hoping for some temp relief at least until then.
    srt8_hmi's Avatar
    srt8_hmi is offline I've probably owned what you're driving!
    Mar 2008
    miami valley(AS IN OHIO)
    do you have the kicker sub in the rear?
    Shiny paint, big wheels, powerful engine.
    My HEMI YouTube channel.
    http://www.youtube.com/srt8hmi
    Halifax Nova Scotia
    Quote Originally Posted by srt8_hmi View Post
    no its only a touring and I forgot to mention that the sound is coming from the front drivers side wheel well.
    fnkychkn's Avatar
    greasy cardboard box
    i'm thinking a seized ball joint.
    Halifax Nova Scotia
    You are of course 100% correct. Mechanic just called to say the ball joint is bad.
    Halifax Nova Scotia
    So to get a seized ball joint fixed requires a new control arm? or am I getting shafted?
    fnkychkn's Avatar
    upper ball joints are serviced with the upper control arm.
    lower ball joints can be serviced seperately.
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Quote Originally Posted by Nuclearjack View Post
    It's worth looking into after-market upper control arms with an adjustable camber. Mopar and Pedders are good options.
    karfreek's Avatar
    karfreek is offline LX Guru
    May 2006
    Fultonville NY (Upstate)
    Awesome. I just had my Pedders installed and a week later I have another noise, it is a creak but a different type coming from what sounds like the drivers side. But muted and intermittent , sounds like the BJ is bad according to this thread. I am sure that an allignment will need to be done, as well.
    What is the moog #? I do not need the adjustable problem solver, just the regular one.
    Jay
    2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed
    2005 Dodge Magnum RT-Can you say...HEMI?
    2004 Chrysler Pacifica AWD-Everything but the kitchen sink.
    carchitect's Avatar
    carchitect is offline has been pardoned by the language filter
    Morton Grove, IL
    has the car been up in the air recently?
    My car is lowered and every time I lift it or someone else lifts it I need to make sure the dust boot over the front shock hasn't caught on the spring. That will cause an awful squeaking during suspension travel when it rubs.
    It's simple and unlikely that it is the issue but it's worth a shot.
    2006 Inferno Red Charger R/T|Zoomers|C&L Intake|Retro Mag 500 Wheels|Pedders Touring Plus w/ adjustable camber|General Grabber UHP 255/55/18|Flat Black Daytona Grille|BT Catch Can|SRT-8 Rear Diffuser|Mopar Chin Spoiler
    karfreek's Avatar
    May 2006
    Just a week ago when the work was done, but I will check it out.
    jay
    progolfer82 is offline LX Padiwan
    Oct 2009
    SoCal Ride: SRT8 Mag
    Eibach adjustable upper control arms are incredible. highly recommended!!
    Oct 2009
    I put new strut mounts on this last week and they dont have a dust boot. The stock strut mounts had the dust boot glue on and couldnt take off. I decided to put back together without and every place I called said its fine.
    Quote Originally Posted by carchitect View Post
    carchitect's Avatar
    Morton Grove, IL
    Quote Originally Posted by progolfer82 View Post
    Really?! I didn't know the OEM mounts had an integral boot. You can buy new boots and bump stops (they come together) from MOOG.
    Whose strut mount did you use?
    To me its a longevity and wear issue. The boots are there to keep foreign material from getting on the piston and then wearing grooves or getting inside the shock body during during suspension travel. Cheap insurance for just a few bucks.
    Oct 2009
    Unfortunately I bought OEM from Dodge. I still have the bump stops on just no dust boot. I didnt know Moog made a strut mount for these cars. I looked for aftermarket and couldnt find anything. I'll post a picture tonight.
