Galvanic Corrosion
I had occasion to remove both my front wheels today, for the first time -- the car is 18 months old; only driven in California and thereabouts (no snow, etc.); factory MSRT wheels, last off ~ a year ago when the slotted rotors were installed. Both were corroded on. I hammered the wheels loose (with a small sledge against the inside of the tires, repeatedly around the circumference of each); wire brushed off as much corrosion as I could; and will coat the contact areas with anti-sieze when I reinstall the wheels.
I was amazed that this happened -- to the extent that it did, this short a time. You might want to check your wheels
06 MSRT. KW, Hotchkis, and REM. Predator, Corsa, and AFE. No more Ram Heads -- Flying Skulls instead (on BT badge, sills, center caps, and underhood; and on Jinah's mats and console cover). Entirely shaved, no rear wiper. SRT door pulls, SRT pedals, Lloyd's HEMI luggage mat, leather shift bezel and matched knob, dash kit matching factory trim, Mopar IPOD, hardwired V1, Mopar hidden hitch, yada yada
