Results 1 to 10 of 10
    Hskrfans's Avatar
    Hskrfans is offline LX Newbie
    Jun 2006
    WA State
    FWD and RWD Rim Question
    HELP! Besides the name, what is the difference between rwd and fwd rims? I honestly had no idea it was that important. I thought rims were rims. There's a set of rims from VERDE called Scorpion. When I tried to order them, I was told that they won't work on a Charger because it's RWD. What the heck? Someone please set this new "car guy" straight.
    Sometimes, it really IS your fault
    dchemi's Avatar
    dchemi is offline LX Enthusiast
    Rochester, NY
    Quote Originally Posted by Hskrfans View Post
    From my online research it seems that the "offset" is the determining factor when a rim is considered FWD or RWD. I found a good
    explanation on this site. http://www.discountedwheelwarehouse....do_I_have_.cfm
    I hope this helps.
    2005 Cool Vanilla Magnum RT (Mopar CAI)
    Token's Avatar
    Token is online now First AWD LX in the 12's N/A
    Center of the LX Universe
    Quote Originally Posted by dchemi View Post
    "offset" is the determining factor when a rim is considered FWD or RWD. I found a good.
    Exactly, rims designitated as FWD typically have substantially higher positive offset.
    12.645@108.18
    Hskrfans's Avatar
    Jun 2006
    WA State
    Thanks for the information!
    VanillaRT4me is offline LX Padiwan
    Jun 2005
    Quote Originally Posted by Token View Post
    Actually, no. It's just the opposite.
    A RWD offset, for our LX cars varies between 12 - 24mm. For the AWD LX car, it'll be 35 - 45mm, usually like a FWD car.
    Token's Avatar
    Quote Originally Posted by VanillaRT4me View Post
    Yea, that's exactly what I said. The factory 18" wheels found on a Magnum RT by example are +20mm for RWD and +55mm for the AWD version.......substantially higher positive offset.
    FWD cars typically have an offset more like the AWD LX.
    12.645@108.18
    Jun 2005
    My mistake. Sincerest apologies.
    Scott is offline AWD Fan
    Dec 2004
    Wisconsin
    Do you know why?
    Token's Avatar
    Quote Originally Posted by Scott View Post
    Do you know why?
    Usually to clear various suspension and driveline components, like the CV joints for example.
    12.645@108.18
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Do you know why?
    The track is wider on the AWD so they had to bring the wheels in or they'd stick out.
    BFNY PERFORMANCE
    RIP My Friend
