Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    JetPilot's Avatar
    JetPilot is offline LX Padiwan
    Aug 2005
    Daytona Beach
    Front Camber Adjustment - Best method
    I see there are several methods offered for adding front camber adjustment on the LX platform.... SPC/Eibach adjutable upper control arm, Pedders Camber bushings, Mopar Camber bolts, ect...
    Any suggestions on the best method? One type better than the other? I currently have the Pedders rear camber kit which worked great but took me a few hours to do myself, I imagine the front kit would be a little easier.
    The SPC/Eibach appears to be a cinch to install but is the tube upper arm and balljoint of any quality?
    Just wondering the Pro's/Con's to each if there is any? Had new treads installed and car aligned, front camber is out further than I thought it would be with the drop Dont want to wear out the inside corners!
    2005 RT Cool Vanilla -
    Finished Mods: Old School Badges, Zoomers, Silver Bezel, VES, Hidden Hitch, Illuminated Door Sills, UConnect, Sirius, Dynamat, SRT8 Wheels matched inserts, Megan Racing Coilover Suspension, Hotchkis Sway Bars, Pedders Radius Bushings, Pedders Bumpsteer, Pedders Rear Camber Kit, SPC Upper Control Arms, Magnum-Force Hood, Painted Spoiler and fog bezel, Predator 91 Tune, Navigation, 300C Door Pulls, Katzkin Seat Skins, Black Seatbelts, Painted calipers, Body Matched Headlights, AAC Halos, Billet upper/lower grill, Falken FK452
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    Well I can just let you know that I went with SPC all the way around and they are great.
    Here is a few images of the front for you:
    Thank you Bigal470
    JetPilot's Avatar
    Aug 2005
    Daytona Beach
    Thanks Noid, any modifications required on the install? Ball joint looks a bit tall compared to stock, any clearance issues?
    Aug 2005
    SoCal
    The installer told me that they had to do a little bit of cutting on the plastic fender well but I would never see it... and guess what... he was right... I can't tell...
    Besides that little thing... everything went smoothly...
    Thank you Bigal470
    Popeye's Hemi's Avatar
    Feb 2008
    Eastern Shore of Maryland
    Quote Originally Posted by JetPilot View Post
    X2, I just finished installing the front upper control arms made by SPC 66030/66035 and it helps to have a computer print out of the alignment to show you where to set the caster adjustment. Took about 1.5 hours to install both sides. using a floor jack and jack stands. I used the SPC rear camber kit for the rear a .75 degree kit with 39.5mm bushings p/n: 66080 one kit on each side. I'm waiting to get my Hotchskis sways and then do the final alignment. I took the car to a Dodge dealership and had the alignment checked and used the color print out from their $40K hunter alignment setup to make the necessary adjustments to the rear camber and front caster. The front camber I set to the middle of the slide. It will take a six point 1-1/16th inch socket or wrench to tighten the top nut at 120 ft lbs. I have 98K miles and was quite surprized at how easy the old front control arms came out. The rear camber bushing took at little longer, but with the right tool it was very straight forward install. Like the other fella said the only rub was the passenger side plastic wheel well and all I did was push it up a little and it cleared the balljoint. Now once the sways are on I can get it aligned.
    Dzhezkov's Avatar
    Dzhezkov is offline LX Newbie
    Apr 2009
    Melbourne, Fl.
    After speaking with JetPilot, I'm interested in the front arms and rear bushings as well. Is there a supporting vendor on this site that offers them? I saw that Jegs carries them, but I'll buy from a supporting vendor if I can.
    JetPilot's Avatar
    Aug 2005
    Daytona Beach
    Thanks Guys, went with the SPC Kit....
    EXTREME's Avatar
    EXTREME is offline Yes, that is my fast driving award.
    Oct 2005
    Flowood, MS
    who has the SPC kit?
    Edit: i found the front right and left sides for 154 each, is that a fair price!?
    US Wheels - Frank Racing - AirHammer - Corsa - AirLift
    22Elite - Billet Tech - 3B Spec HIDs - Diablo Sport
    JT/NoESP - Llumar - Stealth Auto - NavHack
    12.69 @ 109.65
    gameover's Avatar
    gameover is online now voiding warranties
    May 2006
    New Orleans
    ^^Not sure but I just seen a set posted up in the for sale section. Forgot how much he was asking though.
    05 RT . Jett Black . SRT Fascias . UAS . AFEII . Zoomers . Forgiatos . Wilwoods ...
    Aug 2005
    SoCal
    There is a guy selling his set that he is not going to use... he wants 300.00 plus shipping
    Thank you Bigal470
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    link?
    12.69 @ 109.65
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    I got a brand new set never installed I'll sell for 250 shipped if interested.
    Aug 2005
    SoCal
    Now that is a deal...
    Sorry Cam... I didn't know that you had a set...
    Thank you Bigal470
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by Mighty Noid View Post
    It's all good, I only ever advertised it once when I was selling a bunch of stuff, it got lost in the mix. I bought them after I installed the Tein garbage.....oops, I mean suspension and then after I went back to stock, I had no need for them.
    EXTREME's Avatar
    Oct 2005
    Flowood, MS
    HMMMMM ... Check your PMs Cam
    12.69 @ 109.65
