Results 1 to 13 of 13
    robk46 is offline The fixer
    Aug 2009
    Found some wheels at the salvage yard. What are they from?
    They look like Magnum/Charger wheels. I didn't snap a pic, but they're 20inch rims.
    Here are the numbers off the back
    20x8jx240
    1dp88trmaa
    092006 2
    R465
    What are they. Will they fit the Magnum?
    higshemi-less's Avatar
    higshemi-less is offline 0-60- 3.1, 13.5mpg city, 18.5mpg hwy
    Kitchener, Ont
    Running the part number through google came back a bunch of charger SRT references. If they are, they will fit the magnum, you just need to run some 3mm spacers from BT.
    Stock catback, and stock drivetrain
    Nightshade's Avatar
    Nightshade is offline LX Guru
    Kitchener, Ontariooooo
    Quote Originally Posted by Higshemi View Post
    ID CODE 1DP88TRMAA - 20x8 DODGE CHARGER 07-08 DODGE MAGNUM 07-08 5 SPOKES SRT
    carchitect's Avatar
    carchitect is offline has been pardoned by the language filter
    Morton Grove, IL
    Those look like chrome clads found on later Daytona and RT^2 cars... I thought the SRT wheels were 8.5" wide?
    2006 Inferno Red Charger R/T|Zoomers|C&L Intake|Retro Mag 500 Wheels|Pedders Touring Plus w/ adjustable camber|General Grabber UHP 255/55/18|Flat Black Daytona Grille|BT Catch Can|SRT-8 Rear Diffuser|Mopar Chin Spoiler
    Aug 2009
    These wheels definitely have chrome cladding on them.
    carchitect's Avatar
    Morton Grove, IL
    Quote Originally Posted by robk46 View Post
    you should have no problem putting them on an R/T or below trim level
    they won't fit over the the SRT brakes though
    Aug 2009
    Do I need spacers/ If so, where do I get them?
    carchitect's Avatar
    Morton Grove, IL
    No spacers for those wheels if you are running an R/T or 300C and below trim level. If you have a SRT you'd need some mongo spacers. No one here has bothered to do that yet.
    Redfox0099's Avatar
    North Charleston, SC
    Aug 2009
    Quote Originally Posted by Redfox0099 View Post
    How much were they?
    Not sure. I'll bet I can get them pretty cheap though. What's a good price to pay for them? 50 bucks a wheel?
    1FST4DR's Avatar
    Ft Laud.....
    SRT wheels are 20x9.If they are the chrome clads he should be able to get them to fit without issues.
    Redfox0099's Avatar
    Just dont tell them what the wheels are or they will jack up the price on you possibly, play dumb.... Ask for a different nicer set and then when that price seems high point to the ones you REALLY want and ask well how much for Those things?
    Posted via LXFMobile
    jg's Avatar
    jg
    jg is offline LX Padiwan
    Jan 2005
    20x8jx240 = 20x8 -24mm offset.
    As stated above, they are the factory chrome clad wheels that come on Daytonas and R&T packaged Charger/Magnum. The "clad" is a plastic cover that's bonded to the aluminum wheel underneath. The OEM's use this type of wheel to avoid corrosion issues that plague chrome plated aluminum wheels. Cladded wheels are typically lighter in weight also.
