Results 1 to 15 of 15
    Silver Bullit is offline LX Newbie
    Nov 2005
    PA.NJ.NY
    Fittment issue help asap
    I am trying to buy some rims . I need the spec for a AWD car that will work The rims i am looking at 20-115X5-115. Please respond asap.
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    I believe the stock offset for the AWD is +55.
    Hope that helps.
    John Y
    Nov 2005
    PA.NJ.NY
    Okay so in the numbers i was given how do i deturman the offset 115X5-115...
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    I don't understand your numbers. I'm assuming you're looking at a 20" wheel. 5x115 is the proper bolt pattern. What is 20-115? Normally the second measurement would be the width of the wheel i.e. 20 x 8.5 with a bolt pattern of 5x115 and offset of +40 was my old AWD wheels. Then you have to choose a tire size. Mine were 255/45
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    java's Avatar
    java is offline Nuclear User
    Feb 2006
    Baton Rouge, LA
    do a search on this forum and you will find a lot of information. I am running 20x8.5 wuth 34 mm backspacing. Tires are 275/45
    If you don't know what the numbers mean then you should find a shop that does to help you
    My favorite: your facts are flawed and experience sucks.....as does your attitude.
    boschargerrt's Avatar
    boschargerrt is offline BOSChargerRT
    Feb 2006
    Boston
    Quote Originally Posted by java View Post
    have you had any issues w/ running a 34mm spacer....that seems big...thanks - jimmy
    Jimmy - BRIGHT SILVER METALLIC SRT8 I,II,III
    2toned Flat Black Vinyl,CarbonbyDesign,Billet Tech Designer,Razor Edge,SpeedLogix,KW v2,Predator 91 tune,22" 3 pc Covet Forged Wheels ,Nitto 420s,BWoody Sway ends,Hotchkis sways,Magnaflow highflow/c-back,DMH electric cutouts,22elite,BND ALL Quantum Blue/ACESIV,Killerglass,GSM intake,Danko v2 spoiler/Chin spoiler,Grip Rockers,Neffywrap
    TMag's Avatar
    TMag is online now Mopar or Nocar
    Texas
    I may have read this wrong, I don't think he's talking a 34mm spacer, I think its 34mm back spacing on the rim itself.
    Mods- De-molded/Hood to Fender Stripe/Mopar Performance Intake/SRT8 Rear Deck Spoiler. Mods on Deck- Flowmaster Super 10's, Blastin Bob's GPSSR250 Pipes, Diablo InTune, MSRT Rims 20x9/Vred's 270/40/20 fronts, 315/35/20 rears.
    java's Avatar
    Feb 2006
    Baton Rouge, LA
    Quote Originally Posted by boschargerrt View Post
    no spacer. no tire rub, perfect fit
    Nov 2005
    PA.NJ.NY
    Well when i finally got the info the auction was over and they the rims would not have wored any way . They had only 20mm of back spacing. Man those rims where nice.
    billy@bonesenterprises is offline Supporting Vendor
    you need a 20x8.5-20x9.5 size , 5on115mm bolt pattern and an offset anywhere from about +40mm to +55mm depending on width of the rim and a center bore of at least 71.5mm. If you have already pivked out a rim you can gimme a call and give me the specs on it and i can tell you if it will work and also recomend tires too. if you have not already picked out rims, call me and i can help you pick them out and maybe even sell them to you. i just listed about 20 different AWD combos on ebay 2 days ago. You may want to check them out.
    Nov 2005
    PA.NJ.NY
    Please post your ebay number so i can go there tonight. I am really looking for some thing classy i dont want to keep buying rims every two years. this is a one time deal so i need some thing that will really make the car pop with time.....
    java's Avatar
    Feb 2006
    Baton Rouge, LA
    Quote Originally Posted by billy@bonesenterprises View Post
    I would amend the minimum offset numbers to 34 mm, allows more choices
    Nov 2005
    PA.NJ.NY
    Bone speed. Please post your Ebay numbers so i can just go to your listing....
    Turf's Avatar
    Turf is offline '05 Dodge Magnum SXT AWD
    Jan 2006
    Michigan
    Quote Originally Posted by Silver Bullit View Post
    i think this will take you to bones ebay site
    http://stores.ebay.com/BONES-ENTERPRISES
    Nov 2005
    PA.NJ.NY
    Yes thank you thats it. Man i love this stuff. cant get enough. spending money ......LOLO
