Results 1 to 7 of 7
    05silvhemimag's Avatar
    05silvhemimag is offline speedjunkie
    near springfield missouri
    finding the right size tire
    okay i have yokahoma parade spec x and wanting it to be a wider tire on my 20 in rear wheel, they are getting bald and i need some new ones soon, wanting to keep same tires cus the fronts are totaly 90 % good, even after 20,000 miles, but for some reason they dont like tq on the rears if you know what i mean, but wanting a wider tire i have 275/40 right now and you can see the avilable sizes hear
    http://www.tirerack.com/tires/Sizes....=Parada+Spec-X
    i was thinking a 295/45 would work???
    you know i just fing looked at the speed rating of my tire it is R that is 106 mph, that sucks iv ran 170 befor with theis jezz is it that dangerous to run that high over the speed rating, cus i though the guy new what i was doing with a stagered set and needing alot of rubber under the rear DUH..
    Builder Bill Flywheel, Pro Torque 2800 stall,K&N intake,25%UNDERDRIVE PULLIE, SLP LOUDMOUTH EXHAUST!!!,DIABLO 91 cai tune,ZEX 125shot nitrous ,MSD window switch, talor shorties. DYNATEC SUPERMAXX long tubes, and CATLESS..180 t-stat.Tinted tails done buy me. and lots lots more visual mods...race worrior cam NOT INSTALLED
    386 HP at wheels
    466 tq at wheels
    on 100 shot
    OZarks Raceway Personal best 12.8 at 94 mph, 1.9 60 FT. street tires, Faster times to come!
    SRTpete's Avatar
    SRTpete is offline Tire abuser
    Oct 2009
    South Puget Sound, WA
    Nope. Well, it would fit- but your gear ration would be off.
    295 is the width in mm
    45 is the sidewall height (percentage of the tread width) from shoulder to bead seat
    a better sizing would be a 315/35ZR20.
    Why not just run 275s all the way around. You'd be able to rotate the tires, and extend the tread life.
    HEY, U.S. GOVERNMENT!
    My income is NOT your revenue!
    6.1L Hemi Registry #1329
    SRTpete's Avatar
    Oct 2009
    Also- are you sure on that speed rating? where did you get it from?
    If the tire size is 275/40R20 115V, then the R= radial, and the V=speed rating.
    PLUMCRAZY21's Avatar
    PLUMCRAZY21 is offline LX Padiwan
    Aug 2009
    I ran 275 45 w 255 45 in front its was great as long as you stay under 80mph. I wouldn't due it. Scary braking, front end shook, drive shaft clunked, pulled during braking, aligned it.... balance it ..nothing worked. Gave up went back to 255 45 20.... no problems.
    okay i though that the speed rating was always befor rim size okay kool then if v is the rating.. how high is v?
    also i couldnt run a 275 all the way around cus i have 8.5 rims on front and 10 in wide on the back hense the staggered.
    386 HP at wheels
    466 tq at wheels
    on 100 shot
    SRTpete's Avatar
    Oct 2009
    n2fordmuscle's Avatar
    n2fordmuscle is offline LX Guru
    Dec 2008
    Canton, GA
    I'm running 295-40-20 on the rear of my Magnum, and 275-40-20 on the front. With the same rim sizes that you're running.
