Results 1 to 2 of 2
    James@MWP's Avatar
    James@MWP is offline Aim For The Win
    Magnolia, TX
    Experienced advice please
    I had installed the Eibach Pro-Kit onto my Charger. Let it sit for a couple of days and had an alignment performed. After the alignment was complete the installer informed me that I will need a front camber kit.
    He said the camber is not too far out, but if I want to get the max out of a new set of tires that I should install the kit.
    I will be getting the Cooper 255/55/18 tires. Will you please comment on whether purchasing and installing the camber kit is highly recommended or will the tires be fine with the camber shown? Where will I notice more of the loss of tread?
    Left Front
    Actual Before Specified Range
    -0.6 -0.2 -0.5 0.5 Camber
    Right Front
    -1.2 -0.6 -0.8 0.2 Camber
    Left Rear
    -1.2 -1.2 -1.3 -0.1 Camber
    Right Rear
    -1.4 -1.4 -1.3 -0.1 Camber
    Caster and Toe of each are within the specified range.
    Thanks in advance for any comments.
    FRI'D '06 Charger R/T-Stone White
    • FRI-392 Stroker • FRI New Cam • FRI S/S Heads • FRI LT Headers• ProTorque • MF HF Cats • SLP LMII • Volant CAI• Diablo Predator • CMR Tune by Johan • 180T • Eibach Pro-Kit • BT Oil Catch Can • SRT8 Rear Diffuser• NoESP Mod • Mopar TCM
    fnkychkn's Avatar
    greasy cardboard box
    all other variables being equal; slight left pull and wear on inner part of tires.
