I have over the course of the last year been researching possible track wheels for my SRT8. I had originally considered following in MattR's footsteps and picking up a set of 18x8.5" Borbets. My only issue with these wheels was the major limit they put on tire size. With our heavy cars its critical to have as much rubber underneath as possible to provide the grip needed to keep it in line during hard cornering. I had been searching high and low for something with an 18" wheel that was at least 10" wide (for the rear), had enough clearance for the brakes, came in a 5x115 bolt pattern, and had the correct offset. Oh and I wasn't willing to pay nearly $3k for a set of custom CCW's or the like. I had nearly given up, the main sticking point seemed to be the bolt pattern. Its not the most common pattern and because most of the cars it comes on aren't very racey, good, wide 18" wheels are nearly non existent.
This hurdle was however lowered when i found out that RT Nomad was running a set of Enkei RP03's with a 5x114.3 lug pattern. I PM'd him asking what he had to do to make the wheels fit. I figured he had gotten the holes bored out to fit properly. It turns out he didn't have to do anything to get them to fit. All he needed was a set of hubcentric rings and they fit great.
Now I wasn't thrilled with the look of the RP03's, but the fact that he was running them without issue meant a whole slew of race wheels became an option. I found something not too far away from what he got, one of the most ubiquitous club racing wheels around. The Enkei RPF1. Now after a bit of research, I came to the conclusion that the +15 offset would be close enough to perfect that it would be worth a try. A week or so ago I ordered 1 wheel for a test fit, It came in today.
Since my primary roll for this wheel was as a rear wheel, I tried it on the back first.
It went right on with no issue (no rings yet) and it looks like all the clearances are good. Though it does stick out a tad (i might look into getting my fenders pulled a bit)
Lots of brake clearance
No issues on the inside either
Out of some hope that I might be able to run 305's all around I then tried to see if they would fit up front.
They stick out quite a bit further up front
Once again, Lots of brake clearance
Unfortunately the clearance isn't so great on the A arm. It doesnt look like these wheels will be an option on the front
Its not so much the width or offset as it is that the knuckle was designed with a widest wheel fitment of 20x9. The wheel would probably fit just fine if it was a 20" wheel.
New wheel
Stock wheel
This however isn't really a big problem. I should have no trouble fitting my original option for the front wheel, the 18x9.5" +15 RPF1. It will give me 13mm more clearance on the inside and will stick out 13mm less from the fender. It will also allow me to run a 285/35/18's in front while i run 305/35/18's in the rear.
Overall I'm quite happy with how this test fit went and I should collect the other three wheels and four tires over the course of winter and be ready to test them out at the LX track day at NJMP Lightning at the end of March.
Also, if I show up at the track day and half of you bastards have these wheels and Rcomps, I'm going to be mega pissed.![]()
7Likes
