Results 1 to 7 of 7
    RADMAG's Avatar
    RADMAG is offline "The Green Machine"
    Hebron, Indiana
    Eibach Sportline dampers needed?
    Ordered Sportline for the Green Machine, now I am reading info about dampers? Do i need them and where do I find them? Replace the shocks? Need to if i do dampers? Want to get all my ducks in a row- guess I should have researched first- but no damage done yet!!!
    RADMAG
    xevilpetex's Avatar
    xevilpetex is offline Terror of the Northeast
    Long Island, NY
    If you run just the springs, your stock struts will blow out and you will have a rough, bouncy ride. The stock struts arent valved properly for a lower ride height.
    Mar 2008
    Quote Originally Posted by RADMAG View Post
    Your stock shocks probably won't blow out, but they will wear out much quicker when used with lowering springs.
    Stock shocks are not made for the rigors of lowering springs. The higher spring rate (firmer) with stock shocks will result in a very bouncy ride. All that bounce will wear the shocks out quicker.
    Eibach makes the "Pro-dampers" which can be used with any lowering spring but are engineered to be used with the Eibach springs. (Either Pro-kit or Sportline)
    The Pro-kit springs can be used with the stock shocks (per Eibach) because while they lower your car, the spring rate isn't much more than stock.
    Sportline springs, however, have a high enough spring rate that Eibach does not recommend use of stock shocks. (dampers)
    I have the Sportline springs and installed them with stock shocks initially.....Mistake!
    Way too bouncy, bent a front fender, not good. I soon purchased the pro dampers and haven't looked back since. Much better handling, control, No bouncy ride and no more bent fenders.
    My advice (I've been there, done that) is too get the dampers at the same time. You'll either be sorry you didn't or glad you did.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    RADMAG's Avatar
    Hebron, Indiana
    OK- the hole damper (shock) thingy got me! Will invest in the proper dampers soon- but the springs are on the way and not sure I can hold off to get enough cash (without wife knowing)!!!! The Green Machine is not a daily driver- mostly cruise'n and shows- May let it ride till fall and then break it down. Thanks again for clearing that up-
    RADMAG
    legendisdope's Avatar
    legendisdope is offline beastmode
    Sep 2008
    NORTHWEST
    ^ you can put it on now if you want. i have sportlines on stock shocks.. yes it is bouncy when u hit a hole but you can avoid those.. i ride without a problem.. i will upgrade to the eibach dampers soon, probably in the next month or so but right now the ride isnt bothering me too much.
    linuxrc is offline LX Padiwan
    Mar 2009
    Baden, Ontario
    I'm with you. I was confused at first [being a newb in this stuff] not really knowing for sure that damper==shocks. So I was a bit worried, I wanted to make sure that I did not have any bounce once I lowered my car.
    Right now, I have bounce when I corner and hit bumps or when I go over uneven roads. The bounce is more pronounced once you go faster, and I find to be unstable.
    I am getting my eibach sportline, shocks[dampers], and swaybars installed this weekend. If I can find this thread again I will report back. But fireman knows what he's talking about.
    It might cost you a bit more right now, but unless you are doing the install yourself, you might as well go for it. No point in doing this over again and paying someone 2x.
    Good luck
    Scooby's Avatar
    Scooby is offline 06 SXT with Stuff :-)
    Jul 2007
    Peoria, Arizona (it's a Dry Heat, just like Hell)
    Where is the best place (cheapest place ) to buy the Eibach "Pro-dampers" ???
    I have had the Pro-kit, for a couple years with the stock shocks, and the ride has deteriated. I imagine my stock shocks are now toast.
    Old Skool
