Here's the brief story. A few months ago I got the sportlines installed on my car. I was told that my stock dampers were in good shape and that I didn't need to replace them yet. So I went with the suspension guys advice. I have had no issues at all and I have been a proponent of spreading the word that it's not required to have your dampers replaced when you go with the sportlines. Well, since I've had the sportlines on, I've been a little unhappy with the ride height.(rear a little too high) Calls to Eibach and a couple different shops and this forum led me to believe that the resulting drop from a spring install could vary from car to car. Never would I have ever thought that the stock dampers were not allowing my car to realize it's full drop with the sportlines. Apparently that's exactly what it was. For the heck of it and because I had a few extra dollars I went ahead and bought the Pro dampers and had them installed yesterday. I picked up my car and the mechanic says the car dropped about 3/4 inch more(rear) with the Eibach dampers. He tells me how the dampeneing effect is better suited to the springs and how the Eibachs are less stiff than the oem shocks allowing the car to settle in lower or should I say properly for the springs. So here I sit now, finally, with the ride and stance I've wanted all along. So, do you need to replace the dampers when you get sportlines? Ans. - Yes and No. No - if you want the rear a little higher. Yes - if you want to realize the full drop of your sportlines. Overall, I'm a little embarrassed and apologetic for my insistancy on the issue of dampers. Well, live and learn.
By the way here are a few pictures. All pictures are with sportline springs. Before and after pertain to before and after Eibach pro dampers.
before
after
before
after
2010 LX&Beyond Nat'ls Best In Show Magnum Daily Driver
