Results 1 to 5 of 5
Thread: drop
    drew's Avatar
    drew is offline d to the REW
    Nov 2005
    -d E N V E R-
    drop
    has anyone ever just droped the front end? and not the rear i have a huge system and the rear sits pretty low as it is and was wondering what kinda of issues this would produce.
    inferna's Avatar
    inferna is offline 1320in12
    Nov 2005
    oceanside
    you could probably get the mopar springs they are a moderate drop and would level you out.
    Jina's Embroidery's Avatar
    Jina's Embroidery is offline Supporting Vendor
    Jan 2006
    SO. CALIFORNIA
    He's right, I put on the mopar springs only about an inch drop, don't have to worry about speed bumps. Take a look at Grinners ride, one of the nicest on the forum, he only dropped the front.
    Quote Originally Posted by inferna
    http://s135.photobucket.com/albums/q150/jinasse/
    Look in my photobucket link for more examples of my
    Custom Embroidery
    E-MAIL jinasse@sbcglobal.net
    Daniel454's Avatar
    Daniel454 is offline MAG V
    Nov 2005
    Union Grove, AL
    I imagine the Mopar springs are similar to the same spring rate as the stock so using them to lower just the front should be fine.
    However, most other aftermarket springs (Eibach, Hotchkiss, etc) will be higher spring rates.. I would not want to use a higher spring rate on only one half of the car, especially if you ever do any high speed turns...
    While on that note, since most lowering springs have higher spring rates than stock, replacing all four might even you out some as the rear springs wont "settle" as much as the stock ones do...
    Your best option would be coilovers, but they are expensive. I personally would get a good set of moderate or light drop springs, put all 4 on, let it settle a week, and take measurements. I think you will be happy with the effect and will not see a sag in the rear as you are now...
    If you dont think that will make you happy, then stick with the Mopars.
    2005 Dodge Magnum AWD R/T (MINE) - MySpace Profile
    2006 Chrysler 300C SRT8 (Wife's)
    kevinl1058 is offline LX Padiwan
    Oct 2005
    Yourbest option would be going with air suspension. With the advancements in the air ride technology and air spring development in my opinion is the way to go.
