Results 1 to 12 of 12
    bblitz is offline LX Newbie
    Does this fit? 265/45 20 fr, 295/40 20 rear
    Have a 2006 Charger Daytona R/T Top Banana. I want to put these on Niche F-18 20x8.5 fronts and 20x10 rears. I've read this possibly could be done without rubbing. Anybody have any specific knowledge?
    Thanks! Barry
    Technical page: http://www.mhtwheels.com/pdf/specs/N...20B%20M857.pdf
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Ask RobAGD,he has those sizes on his Mag!
    BFNY PERFORMANCE
    RIP My Friend
    Hmmm. Can't find that name. ???
    FactoryD's Avatar
    FactoryD is offline Gettin' high on the downlow
    Nov 2005
    Phoenix, AZ
    I have those sizes on my Magnum too. Even while lowered w/ Eibach Prolines, I have no rubbing issues.
    RobAGD's Avatar
    Reston, Va
    i have it all covered in my registery. Lots of stuff in there along with a LOT of pictures.
    Stock wont run
    Mopar wont rub
    Hotchkis MAY rub
    Eibach SHOUDL rub
    KW depends on settings
    If you want to get into this in depth, PM me
    -Robert
    billy@bonesenterprises is offline Supporting Vendor
    hey factory D, you said you have those wheels and you have no rubbing but do you have those tires sizes as well and no rubbing with it lowered? the reason i ask is that on another thread about putting a 295 40 20 on the rear the guy had it lowered and he said he had quite a bit of rubbing with the 295 40 20 in the rear, he said almost anytime he had more than 1/2 tank of gas or any weight in the rear he had rubbing and when he hit bumps or in hard corners. he had rubbing. let me know. we just did a 275 40 20 in the front and a 315 35 20 in the rear and since the 315 35 20 is about 6/10s of an inch less in overall diameter and closer to the original size of 225 60 18 they might be a better choice. but you gotta have the right offset to handle that wide meat. on that 10 inch wide wheel, it needs to be around +30mm. i have posted the pics we took in the link below. scroll to the bottom of the page and you will see a gray magnum R/T with the chrome 20 inch 300C SRT8 wheels we sell that has a 275 40 20 on the front and a 315 35 20 on the rear.
    http://www.bonesenterprises.com/cust...rt8endpage.htm
    RobAGD's Avatar
    Reston, Va
    Billy look at the post in my sig about the rub issues. Oddly Stinky ( FactoryD ) and I have teh same wheels and tire package but differnt drops.
    -Robert
    monty1269's Avatar
    monty1269 is offline Looking for a job too...
    Aug 2005
    Pompano Beach, Florida
    yep...the Hotchkis-drop creates a rub when cornering hard. I can take pictures of the little shavings off my tires if need be...But I'm sure you get the idea. It's the O.D. that is getting me.....
    Billet Tech Goodies EVERYWHERE Diablo tuned!! Inertia SPARTAN CAM 214/218, 113 LSA, 3.06 gears, FTI 3600 TC, 17 X 8.5 Borbet TS w/ 275/40 Hoosiers : Hemi Registry 0436
    Best 60'= 1.896 (stock TC and gear) ET= 12.841 (pre-Eagle heads & 6.1 intake manifold)
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    Wow! Those are monstrous Billy! I can't imagine that's recommend, but more importantly - is it safe?
    Netsrac's Avatar
    Netsrac is offline MMM Montreal Magnum Mania
    Oct 2005
    Montreal, Quebec
    I am at stock height and running 275 40 20 in all corners.
    Have had no problems and OD is close to stock.
    May 2004
    PHXAZ
    I put 275-45-20 Toyo Proxes S/T on the front of my SRT with stock wheels and suspension and there was constant rub from the A-arm. Lucky I was planning on putting them on the back anyway.
    Thanks for everybody's thoughtful replies. Turns out the Niche wheels are not the right fitment (my local tire guy was wrong). I am going with the same setup RobAGD uses, Foose Nitrous 20x8.5 with 265/45 20 and 20x10 with 295/40 20. My R/T is not and will not be lowered, so this should be fine. I considered the 315/35 20, but that requires a 20x10.5 which is not available in the Foose Nitrous.
