Results 1 to 8 of 8
    MR. WONKA's Avatar
    MR. WONKA is offline glued to the road.......
    Jul 2008
    Moses Lake, WA
    Diablo tire height
    I was going to change my tire height from my predator,however I think the measurements where in metric. Here are the numbers off of my tires 275/40 R20 106W. What is what? Is the 275 the height, and the 106 the width? Info I need info.
    TMag's Avatar
    TMag is online now Mopar or Nocar
    Texas
    275/40/20
    275 is width
    40 is sidewall size
    20 is height(rim)
    Basically thats it.
    Mods- De-molded/Hood to Fender Stripe/Mopar Performance Intake/SRT8 Rear Deck Spoiler. Mods on Deck- Flowmaster Super 10's, Blastin Bob's GPSSR250 Pipes, Diablo InTune, MSRT Rims 20x9/Vred's 270/40/20 fronts, 315/35/20 rears.
    TheBeastMaster's Avatar
    TheBeastMaster is offline Does it look like it's got a Hemi?
    Jun 2008
    Georgia
    40 means the sidewall height is 40% of the tire width. So 40% of 275mm means the tire sidewall height is 110 mm. Tires of the same size may vary from one manufacturer to another. Don't input tire size to the Predator by the tire info. Input the overall height of the tire so the Predator can adjust based on that. However, going from 255/45 to 275/40 will only cause a 0.85mph difference in speedometer reading, so it's not critical to adjust in the Predator.
    What we're dealing with here, is a complete lack of respect for the law! Speedfactory Stage 1, Zoomers,Airaid-S,BT,Grip,Sportwing
    ewrecker2003's Avatar
    ewrecker2003 is offline lost!!!!!!!
    Racine,WI
    Just use the tire size input insteed of the inches works much easier
    Eric
    05 Magnum R/T
    Get that LX SMOKING
    jba headers,high flow cats,jba cat back,spartan,CAI,tuned RDP(email)
    installed 8/7/8 protorque2800
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    If the tire size you have is a choice on the menu use it ... otherwise, measure the tire with a tape measure from the ground up to the top of the tire and that is the size in inches to enter ...
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    here's a tire size calculator
    http://www.miata.net/garage/tirecalc.html
    28.7" high
    If you use the metric settings in the diablo, the first to enter is number is 275, the second is 40, and third is rim height 20.
    05_BLKMAG_20 is offline Matt18
    Jun 2007
    Austin TX
    Have any one else have this issue. I have entered it with the hieght and the tire size of 255 45 20 and I think the speedo is about 5 miles too fast.
    Has anyone had the same issues.
    Thanks
    Feb 2007
    Quote Originally Posted by Matthole18 View Post
    Have any one else have this issue. I have entered it with the height and the tire size of 255 45 20 and I think the speedo is about 5 miles too fast.
    Thanks
    Do you have a way of checking? If you entered it in right should be dead on. We have these Radar speed signs all over Orange Co. Ca. at school zones and mine appears to be right on the nose if the signs are right?
    Here in California the state allows for a 3% discrepancy.
