Not the stock tire (lol), but another model all-season (V rated 150mph) in the stock size of 225/60-18:
http://www.conti-online.com/generator/www/us/en/continental/automobile/general/news/policevehicles_en.html
Quote: “The new flagship tire for the Continental brand, the ContiProContact, has been selected as Original Equipment (OE) for Dodge’s much-anticipated police-pursuit vehicles, the 2006 Dodge Charger and Magnum.”
The website has the typical overused tire advertising verbiage that has become meaningless, e.g. “exceptional performance”, “superior traction” blah, blah. However, since these tires are intended for police duty, they probably have been tested for aggressive driving. Plus, Continental must have learned a lot from customer “feedback” on the stock tires. These ContiProContact’s would benefit from that testing and experience, er, right?
All tire manufacturers produce some good models, so it’s possible.
The ContiProContact’s have the same load rating as the stock tire, but I don't know enough about tire design to know if the same load spec necessarily indicates the same sidewall softness of the oem TouringContacts. Hopefully, the newer ProContacts have a better belt configuration for more lateral stability.
A Continental datasheet compares some performance characteristics of the ProContact with the OEM TouringContact. Wet performance and lower rolling resistance are the largest changes.
http://www.conti-online.com/generato...tasheet_en.pdf
Also of interest is the 150 mph rated winter tire, ContiWinterContact TS790V in a 225/60R18 (103V). At least one forum member reported being pleased with.
Not in the above linked article is another Conti performance tire in 255/55 size, 109 load rated.
As an aside, I’m not so pleased that the LX’s are going to be police vehicles. I think it detracts from the cool/unique quotient of our cars. However, I can see that LXs will perform this duty well and certainly contribute to profitability. They can take a big hit from the rear, tested at 50 mph. Crown Vic’s are weak from the rear, with fiery consequences.
Scott
P.S. If you’re still running the stock conti’s, be vigilant about keeping the tires inflated. Heavy RT’s need 38 to 40 psi or more for performance driving. For an AWD, 40/38 psi front/rear is a nice combination for performance and comfort.
