Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Thread: Coy C-5 wheels
    Lex
    Lex is offline Load Toad
    Jan 2005
    Pennsylvania
    Coy C-5 wheels
    got these wheels on the way for the R/T.....putting them on BFG Gforce T/A kdws 245/40/20. was told it's the same diameter as the stock wheels/tires. confirmation of this would be much appreciated from anyone that knows.
    armadillo is offline Frequent Flyer
    Nov 2004
    Chandler AZ/ Houston TX
    Quote Originally Posted by Lex
    got these wheels on the way for the R/T.... BFG Gforce T/A kdws 245/40/20. was told it's the same diameter as the stock wheels/tires. confirmation of this would be much appreciated from anyone that knows.
    yep, the 245-40-20 is the same diameter.
    Vaderwagon's Avatar
    Vaderwagon is offline LX Padiwan
    Marengo, Ohio
    Here is a tireszize calculator that I found that can be helpful http://www.powerdog.com/tiresize.cgi
    Just type in your size and any other sizes to compare.
    Outside of a dog, a book is a mans best friend. Inside of a dog it's too dark to read. -Groucho Marx
    2005 Black Pearl Magnum RT
    Eibachs, SRT8 suspension, K&N CAI, SuperChips FP, Mopar hidden hitch, Blastin Bobs pipes, Kumho STX 255-55-18.
    Lex
    Jan 2005
    Pennsylvania
    thanks for the help. according to that calculator, the diam. is .9" smaller. will this give me esp failure?
    Silver1's Avatar
    Silver1 is offline disLXic
    Ketchum, Idaho
    245/45-20 will be the same diameter as stock...
    BlkHemiMag's Avatar
    BlkHemiMag is offline <--- Practice Safe sex
    Jan 2005
    Ft Walton Beach
    Even if you're running smaller tires, the computer don't know that. Now, run different sized front and rear and the computer might take notice.
    2005 Magnum RT
    1972 Chev K10 lifted..
    1972 Chev C10 lowered..
    cluv's Avatar
    cluv is offline Magnum Aficionado
    May 2004
    Irving, TX
    Quote Originally Posted by BlkHemiMag
    I'm running 245/40/20's in front, and 275/50/20's in back, and I haven't had any problems from the computer.
    Jun 2005
    IN THE ETHER
    Did you check the correct bolt pattern for those wheels? Last time I checked, the Coys wheels were offered in a 5X4.5(5X114.3) bolt pattern. I think you need the 5X115 bolt pattern if I remember correctly from reading from these posts. Someone correct me if I'm wrong.
    I don't want to rain on your parade but I do want you to get the correct bolt pattern for your wheels so that you wont get any vibration problems.
    Good Luck
    Jose
    PEACE OUT YO!!!
    Lex
    Jan 2005
    Pennsylvania
    uh-oh, good question. I spoke directly to the owner's son in Utah. He said that they've already fit over 20 Magnums. So I figured he knew what the correct bolt pattern would be. Guess I'll find out soon enough; I get them Friday!
    Thanks for your concern. I'll have to check into it.
    boggart's Avatar
    Pittsburg, KS
    They are 5*4.5, not 5*115mm. They'll go on, and it seems some have had problems, and some have not. This is my understanding of reading about the wheels on this and other forums.
    LtlDad's Avatar
    LtlDad is offline LX Padiwan
    Nov 2004
    OC, CA
    Quote Originally Posted by Shaggin Magnum
    Good Luck
    Jose
    That is why I ended up getting the RT wheels for my SXT. I wanted the AR Torq IIs or Coys, but neither had correct bolt pattern. Not sure if any manufacturer has the EXACT/Correct one and most are using the Mustang/universal 114.3 size.
    diamondrmp's Avatar
    diamondrmp is offline LX Guru
    Northern California
    Find PhatJay member here he can hook you up with some hubcentric rings for your Coys. I have Coy C5s and after installing the rings they are vibration free ride!
    Rockadile's Avatar
    Rockadile is offline Giggidy, giggidy, gig-gi-dy!
    Schwenksville, PA
    Tire shop I spoke with said there's not much available (except for custom). But if we wati a bit, the manufacturers will be puttin some wheels out soon.
    Magnum Club Member #1053
    Procrastination is the key to flexibility.
    Lex
    Jan 2005
    Pennsylvania
    diamondrmp, where did you get your Coy's? do you like them?? thanks for the tip on the rings. i'll pm PhatJay in the morning.
    the rep I spoke with said he used 4.5" backspacing. does that have anything to do with the bolt pattern?
    diamondrmp's Avatar
    Northern California
    I got my Coys straight from Coys. Backspacing and bolt pattern are different. PhatJay can give you all the correct info onit.
