Results 1 to 10 of 10
    RTracer's Avatar
    RTracer is offline he who likes fast car
    Martinez, ca
    A couple of questions for those that have installed springs themselves
    Ok, I am finally installing my lowering springs on my magnum on Wed night.
    I got couple of questions for those that have done this
    -I will be using external spring compressors for the fronts, do you need the compressors for the rear, or can you simply lower the control arms enough to get them out without the use of the compressors.
    If you did use the spring compressors on the rears, did you use the same for the rears as for the fronts
    -The instructions show a special tool for the nut on the strut, do you really need this? I'm betting not.
    -Any special hints that may save my brother and I time
    -We will be using a lift, and air tools...yessssssss!
    -I have printed and read the thread the the KB
    Tools I plan on having at hand
    -spring compressor
    -ball joint puller
    -lift
    -a whole shop of wrenches and the like.
    ohhh so excited, and even though they have been posted before, plenty of pics to come
    Thanks in advance for any info
    2006 Charger R/T R&T Black..SRT8 stuff/JBA stuff
    2005 Magnum R/T inferno red-now in magnum heaven
    1966 Galaxie fastback-C6 w/460BB..sold, but not forgotten
    Long Island RT's Avatar
    Long Island RT is offline LX Fluzie
    Nov 2004
    Long Island NY
    Quote Originally Posted by RTracer
    -I will be using external spring compressors for the fronts, do you need the compressors for the rear, or can you simply lower the control arms enough to get them out without the use of the compressors. No compressor needed in the back - once you unbolt the lower control arm from the chasis and slowly release the pressure with your jack - they come right out. You'll have 'em out quickly in the back - hard part is to get the bolt holes lined up again on re-assembly - it takes some clever jack guiding and sneaker pushing....
    -The instructions show a special tool for the nut on the strut, do you really need this? I'm betting not. - No - I used a vise grip with a piece of rubber tubing on the shock shaft to prevent the shaft from turning (and being scarred). Once the spring pressure is released the nut came off pretty easily
    -Any special hints that may save my brother and I time - Make sure you position the front springs on exactly the same way back into the strut assembly - mine was off a few degrees and I had to take it apart again to re-align
    Don't try and turn the lower front strut nut to remove the strut - its welded on - you have to undo the bolt! OK - it was dark down there and stupid is as stupid does. All I kept thinking is "Damn this thing is tight!"
    -spring compressor
    -ball joint puller
    -lift
    -a whole shop of wrenches and the like. - Make sure they are metric.
    Good luck - and may your corners end quicker!
    RTracer's Avatar
    Martinez, ca
    Thanks Longisland Rt, I was hoping to hear from ya.
    \Thanks again
    Brian
    kevinl1058 is offline LX Padiwan
    Oct 2005
    The only hard part was lining up the rear bolt holes. Other than that pretty straight forward. Good luck Kevin
    RTracer's Avatar
    Martinez, ca
    Put the fronts in last night....easy peezy. Gonna throw the rears in on Wed.
    The car actually looks pretty cool with just the front dropped a bit. Gives her that ols school raked look!
    Animal451's Avatar
    Animal451 is offline LX Newbie
    Oct 2005
    Modesto, CA
    What springs are you using and do they work with the Daytona suspension?
    Airaid CAI; 180 T-Stat; Spartan MAX Cam
    JBA Longtubes & Catback; ESP Disable, SLP Linelock, SLP Underdrive, Wavetrac LSD
    Trinity/CMR Tune, 6.1L MTCM, Moes Performance TB
    Innovate LC-1 Wideband,
    R1 Drilled/Slotted Rotors
    SOLD: Go-Mango #913 of 4000
    Davesatdoasisbar's Avatar
    Davesatdoasisbar is online now Belly your cans up on to the Oasis Bar
    I just hope its not the place I die in.
    please take pictures of the raked look
    RTracer's Avatar
    Martinez, ca
    Will take a couple of shots tonight before I install the rears
    Black on Black's Avatar
    Black on Black is offline and there's no going back
    Chicagoland
    I needed spring compressors for the rears myself... didn't get as lucky as the other guy. I used the same ones on the front.
    '05 Dodge Magnum R/T - Brilliant Black Pearlcoat - SOLD
    '05 Pontiac GTO - Cyclone Gray M6 - "CycloneLS2" at ls2gto.com
    RTracer's Avatar
    Martinez, ca
    Quote Originally Posted by Davesatdoasisbar
    Oops, check out my thread on the "magnum general discussion"
