Here's the latest on my attempts to get race quality coilovers for the Hemi based cars:
I've now been driving on the rear shocks in coilover formation for about a week. Originally, there were some extra clearance issues that had to be addressed. We had some new pieces custom fabricated, and I installed them last Tuesday.
Here's the functionality so far:
Ride height:
It looks like I can drop the rear about 1 1/2 inches from stock without the springs ever unloading. If we add a take-up spring, or are just willing to live with the suspension completely unloading if you go airborne (not likely) then there's enough adjustment to lower the car about 3 1/2". I don't think that's even physically possible without the wheels hitting the wheel wells, so basically, I could lower the car as much as would ever be possible under any setup. I've adjusted ride height about 10 times by now. Because I don't have new suspension on the front yet, I settled with lowering the back about one inch, just to level the car out. I had it too low at first, and it looked like the rear was sagging. Popped it back up 1/2" to get a nice level stance.
Adjusting ride height took about 3 minutes per side.
Springs:
I have 550, 450, and 350 pound springs. I tested 550's first, and I should have been on a road course. The car was on rails, but ride quality on country roads was bone-jarring to say the least. Then I tried the 450 pound springs. Bingo! This is the spring for me for street use. Incidentally, I was able to completely change springs in 30 minutes, while talking on the phone. If focused, I think spring change-outs can be done in 20 minutes a side.
Rebound and compression damping:
Once I settled on the 450 pound springs for the street, I started playing with the damping. Setting both rebound and compression to almost full stiff was enough to make every little crack in the road transmit to the car. But I was still able to turn corners with a lot less lean than stock, and handling was much improved. The car would probably still understeer, but it was much closer to a balanced set-up. I'd need to be on a road course to actually flog my car to set it up best.
I then set the damping to full soft. The result was soft enough that the springs got a little bouncy, so I started dialing in some damping. I ultimately got a ride that was much smoother than stock, yet handled better than stock as well.
Adjusting damping from full firm to full soft took about 20 seconds per side.
Weight savings:
The suspension drops 5.4 pounds per side, but because the shocks are mounted body up, you drop even more unsprung weight, which is great for racing/handling. I dropped almost 9 pounds of unsprung weight per side.
Here's a couple of pictures to try to show what they look like.
These are still not a marketable coilover. There's too much custom work to make them fit. I think they may get down to about $900-$950 per rear pair including one set of springs. Currently, to replicate my coilovers is probably closer to $1200 per rear pair due to the needed custom pieces.
We'll see what happens.
Thanks for watching.
