Originally Posted by
skeletonizer
Do you have stock rotors? It is possible (not probable) that you are experiencing "knock back".
If this happens after hard cornering without brake applied. The outboard brake rotor can flex enough that as it travels through the caliper it's at a slight angle, thus forcing the piston(s) back into the caliper. The pull is experienced when the unaffected brake grabs before the slack in the other one is taken up.
If you preload your brakes when approaching a corner it will minimize knockback. The problem has been adressed electronically in the Challenger SRT8 by using the ABS pump to keep the pads against the rotors.
After reading about this I went out and tried to make it happen in my SRT. I think that it would have to be very extreme driving to make it happen as I could only slightly feel it and only after a four wheel drift.
It was fun though.
This occurs after braking relatively quickly (but not like ABS-Engaging speeds) from.. Oh i'd say 40mph or more. Your theory seems plausible, although it happens to me after straight acceleration :(. To further the description -its like the car suddenly jerks to one side or another after braking. Sometimes it'll go left THEN go right. We're not talking like 90* turn pulling here. But enough to jerk me into the next lane if I let it do what it wants. The wheel follows b/c I can feel it through the wheel. I mean you can actually see it turning slightly. Very very scary.
Rotors are stock. They were replaced by the dealership. Pads are semi-metallic Mopar "Value" brakepads (yeah, I went cheap). A quick trip to RS Strauss revealed that the rear pads have about 35% left on them and the fronts are good (they didn't give me a percentage). Again, I get no vibration so I dont think they are warped, just this really scary & dangerous pulling problem.
2006 Dodge Charger RT - 6.1L motor, 3.06 rear, Brembos, SRT steering & electronics * KWV2 suspension * Hotchkis sways * BWoody endlinks * SRT fascia & spoiler * Trufiber SRT hood * MSRT wheels * 6000k HID lows/fogs * Aftermarket LED headlamps * MyGIG * 1ST COMPLETE '06-'08 INTERIOR CONVERSION * AFE Stage2 CAI * catless mids * 170 tstat * Predator 93oct tune... & a bunch of other sh!t I cant remember!
