Results 1 to 6 of 6
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Can anyone settle this debate?
    OK, so when I bought my Magnum a few weeks ago, it already had a set of brand new looking Falken ZE-912 tires on it mounted on the stock wheels. Anyway so Friday leaving work out in the parking lot a co-worker looks at the tires and says "I just bought those exact same tires for my girl friends car last week".
    Then he starts looking at mine and says they were mounted wrong. He claims that the tires should have the "outside" label showing on the drivers side, and the "inside" label should be showing on the passenger side. Mine are showing "outside" on both sides of the car, the way I believe it should be.
    So does "outside" mean the tires should all be mounted with that showing on the outside like I think, or outside showing on the left side and inside showing on the right side like he said? That doesn't make any sense to me.
    I would think a rotation arrow would be there if they were actually directional tires.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    NC-SXT's Avatar
    NC Coast
    Hybrid-asymmetric tread design provides superior wet traction and allows for free rotation
    I am pretty sure these are not rotational tires. Yes they would have an arrow. You had them mounted right. Your friend has been smoking something.
    WWW.DodgeMagnumGrille.com
    89grand's Avatar
    Phoenix, AZ
    Quote Originally Posted by NC-SXT View Post
    That's exactly what I thought.
    2000 Jeep Wrangler
    gn300's Avatar
    gn300 is offline Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    inside would be towards the "inside of the car"or you should only see the word outside
    Hard to do a inside /ouside rotation!
    goldsmi is offline RIFed Xeroid
    Sep 2007
    Rochester, NY
    My Firestone Firehawk GTs are marked 'outside' and 'inside'.
    Asymmetric tread, you should only see the word 'outside' regardless of left or right side mounting.
    Quote Originally Posted by 89grand View Post
    OK....He claims that the tires should have the "outside" label showing on the drivers side, and the "inside" label should be showing on the passenger side...
    if he was making only right hand turns on a track, that may be correct. for the street, you have them mounted correct.
