Hunter makes some nice equipment. We use their tire mounting/balancing equipment, as well as their alignment machine (camera style).
I agree, those specs aren't
too bad. Over time, you may get some cupping on the inside edge of the tires. The OEM tires (Goodyear RSA) have a rounded shoulder and will not get torn up too bad. If you are running wider tires, and/or tires that have more of a "square" shoulder, the inside edge wear will be more noticeable and occur sooner.
Having said all of this, your car should now feel like it is on rails
