Results 1 to 7 of 7
    smoove7410's Avatar
    smoove7410 is offline 2.0 x 3.0 x 5.0 ÷ 10.0 + 1.0 = 2.0˛
    Apr 2004
    Los Angeles
    Exclamation --- Camber Correction ---
    I have a set of KW V2s that I will be receiving (thanks clean300c) in the next week. I am debating whether I should install them before I can get the camber correction parts or not. Does anyone have any input? Will the tires wear that bad in 2 months? Would I save $$$ on the install if I installed them all at once? The rear bushings are no problem, but the front arms are $$$$. I won't have the cash for the camber parts for at least a month or two, or three. Also, any suggestions on camber solutions....ie pedders vs SPC and are there any other ways to correct the front camber without buying the full arms?
    Thanks
    __________________
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    Well it depends on how manys miles you are going to put on your car... if you put miles on it everyday... then I would do everything at once... it should be cheaper in labor... if it is a weekend car... then you can wait... it shouldn't do to much damage on the inner tires...
    I have the SPC stuff and I love it...
    Also there is no other way to do the front without changing the arms...
    Just a little FYI... Eibach also has them and they are cheaper and guess what... they are made by SPC... go figure...
    Hope that this helps...
    Thank you Bigal470
    smoove7410's Avatar
    Apr 2004
    Los Angeles
    ^^Thanks noid. Who has the eibachs the cheapest? This is what I found......
    SPC rear $80 shipped --- http://cgi.ebay.com/ebaymotors/SPC-R...ht_4320wt_1597
    SPC front $320 shipped ---- http://cgi.ebay.com/ebaymotors/SPC-F...ht_4164wt_1597
    Eibachs rear $52 + shipping or $54 at tire rack ---- http://www.2kracing.com/Product/19926.html
    Eibachs front $260 -- tire rack
    NVRDUN's Avatar
    NVRDUN is offline LX Guru
    Las Vegas
    I did not need the front camber kit. The dealer was able to dial in the fronts to "within specs". However I did need the kit for the rear. The LX has two different size bushings in the rear, so make sure to get the right one. I had to re-order. I have the SPC kit and I got mine from Amazon for less than tirerack price!
    Fargo59's Avatar
    if the front isnt out by much, chrysler used to issue out "correcting" bolts for the lower control arms and tension struts. they can take a couple points of camber out, but no more. you replace the lower control arm bolt, and push the arm in the 1/8th of an inch or so it will go, then tighten it up. this might be enough for you. as for the rear, chrysler also sells lengthened rear camber links, but they are cast iron, and pricey. my check showed 500 bucks for a pair. i'll try and find the part number for the offset bolts somewhere. i believe it was in an early 05 TSB for steering pull.
    for comparison, with my V1's lowered 2 inches or so (on an RT)
    front camber is -1.25 degrees
    rear camber is -1.5 degrees
    pukkaSRT8's Avatar
    pukkaSRT8 is offline puk·ka [adj.] authentic, 1st class
    NW Chicago Burbs
    after lowering my car, i got a full alignment done and was able to get back to within specs. whilst camber is an issue, toe in is more important to correct on these cars so im told.
    send me your email addy and ill forward you a copy of the chrysler tsb with the updated alignment specs in it with instructions on how to do a cradle adjustment to adjust the camber.
    smoove7410's Avatar
    Apr 2004
    Los Angeles
    Quote Originally Posted by NVRDUN View Post
    Nice info. How low did you go? So, should I grab the rear kit, and then see what they can do with the front? Did the dealer install the correcting bolts Fargo mentioned in the front? Good call on amazon...I'll take a look.
    Quote Originally Posted by fargo59 View Post
    Thanks for the info Fargo. I will take a look into this.
    Quote Originally Posted by pukkaSRT8 View Post
    PM sent puk.
