Results 1 to 5 of 5
Thread: Brake pad glue
    Dupie24's Avatar
    Dupie24 is offline Go Dupont Racing!
    Nov 2004
    SoCal
    Brake pad glue
    I noticed the brake pads on our magnum rt were glued to the caliper. When I looked in the service manual on brake pad replacement, no mention of glue. Does anyone know what DC uses to glue the pads? I am now getting a slight squeek in the morning and I'm sure its because the pads are not tight. Thanks guys...
    2005 Inferno Red Magnum RT
    Group I and II, sunroof, tow package, nav, sirius, Uconnect, auto headlights, 20" American Racing Torq-Thrust M Wheels, 245/45/R20 Kuhmo Ecsta ASX tires, KW V2 coilover suspension, Hotchkis sway bars, Zoomers Cat Back Exhaust, Aria CAI. LED smoked tail lights. Shaved rear hatch. Pinstriping by 2-Stix. Custom painted palm tree headlights w\halos & painted fog lamps w\halos by AAC.
    Custom Billet Tech "palm tree" pieces
    And lots of little visual mods that make it ours!
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Uh... don't worry about the glue, the pads come glued to the backing plate when you buy them... that 1/8" thick piece of steel on the back of the pad is a part of the pad, not the caliper!
    Don
    Dupie24's Avatar
    Nov 2004
    SoCal
    Quote Originally Posted by GasGunR
    Don
    I realize that, I did not make myself clear, sorry. What I am saying is that the shim on back of the pad was "glued" to the caliper. New pads have the shim on them, I just want to reglue the pad/shim assembly like it was when it left the factory.
    fnkychkn's Avatar
    greasy cardboard box
    try this stuff. works quite well.
    Dupie24's Avatar
    Nov 2004
    SoCal
    Quote Originally Posted by fnkychkn
    Thanks, it worked like a charm!
