If the tires are 35 series instead of 45 series, they are a taller tire with e larger circumference... meaning that for every revolution of the wheel / tire, your car goes farther than your odometer reads.
Lets say the 35 series tire is 30" tall and the 45 series tire is 31' tall, every time the wheel makes a revolution you would be going slightly over 3" FARTHER than the odometer would be reading. I'm not going to do the math but it takes alot of 3 inches to make a mile, and even if it were off, it would be in your favor on the warranty, not the other way around. Therefore you have no complaint IMO. Some people have purposely used 45 series tires on 20" rims as they felt it looked better with the wheel wells filled a bit more and they felt safer driving over the potholes with more tire between the rim and the hole.
